cannot dial out
Discussion in '3CX Phone System - General' started by pdq, Aug 9, 2010.
  1. pdq
    pdq
    Dec 3, 2009
    82
    New install, outbound rule and PAtton 4114 configuration entered. Inbound calls work fine. I get a fast busy immediasley when I click dial.
    Logs:
    15:41:23.741 [CM503020]: Normal call termination. Reason: Not found
    15:41:23.740 [CM503016]: Call(8): Attempt to reach <sip:8819414560559@192.168.11.14> failed. Reason: Not Found
    15:41:23.739 [CM503014]: Call(8): No known route to target: <sip:8819414560559@192.168.11.14>
    15:41:23.734 [CM503010]: Making route(s) to <sip:8819414560559@192.168.11.14>
    15:41:23.723 [CM505001]: Ext.110: Device info: Device Identified: [Man: Cisco;Mod: SPA Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco/SPA502G-7.1.3a] PBX contact: [sip:110@192.168.11.14:5060]
    15:41:23.715 [CM503001]: Call(8): Incoming call from Ext.110 to <sip:8819414560559@192.168.11.14>
    15:38:58.751 [CM503008]: Call(7): Call is terminated
    15:38:53.394 Currently active calls - 1: [7]
    15:38:44.305 [CM503007]: Call(7): Device joined: sip:100@192.168.11.106:5060
    15:38:44.296 [CM503007]: Call(7): Device joined: sip:10001@192.168.11.36:5062
    15:38:23.394 Currently active calls - 1: [7]
    Frustrated in Florida
  2. pdq
    pdq
    Dec 3, 2009
    82
    Frustration fixed due to _____.
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Not sure what your last post means,. but your logs are telling you that you do not have an outbound rule to satisfy the number being dialed.
  4. pdq
    pdq
    Dec 3, 2009
    82
    It means I found the issue in the outbound rule.
