Cannot dial to fax server from internal
Discussion in '3CX Phone System - General' started by millsey, Jan 25, 2012.
  1. millsey
    millsey New Member
    Dec 21, 2011
    203
    Due tyo having to port all our numbers within an ISDN line we are going to get FAX calls hitting our Reception. We need to be able to frorward these quickly to the fax server, but I cannot dial the fax server (888 on this system), the call is dropped after a second or two.
    How can we achieve this please?
    Millsey
    11,113
    329
    What does the 3CX log show for the call?
  3. millsey
    millsey New Member
    Dec 21, 2011
    203
    17:23:16.801 [CM503008]: Call(113): Call is terminated
    17:23:15.152 [CM503007]: Call(113): Device joined: sip:888@89.0.3.1:5100;user=phone
    17:23:15.150 [CM503007]: Call(113): Device joined: sip:103@89.0.5.0:5060;user=phone
    17:23:15.146 [CM503002]: Call(113): Alerting sip:888@89.0.3.1:5100;user=phone
    17:23:15.104 [CM503025]: Call(113): Calling @[Dev:sip:888@89.0.3.1:5100;user=phone]
    17:23:15.057 [CM503004]: Call(113): Route 1: @[Dev:sip:888@89.0.3.1:5100;user=phone]
    17:23:15.057 [CM503010]: Making route(s) to <sip:888@89.0.3.1;user=phone>
    17:23:15.056 [CM505001]: Ext.103: Device info: Device Identified: [Man: GrandStream;Mod: GXP series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP2100 1.0.1.110] PBX contact: [sip:103@89.0.3.1:5060]
    This is me dialling 888 from extension 103.
  4. leejor
    11,113
    329
    I'm not positive that this is going to work. I haven't really had to get into into fax over 3CX as i just have a fax machine connected directly to a PSTN line.
    http://www.3cx.com/forums/fax-reception-problem-21849.html#p110419
    What you might try, after hours, is sending an incoming fax call directly to the fax server, no transfer involved, see if that works. You may have to do something like this using a separate fax number.
    We'll see if someone else, with more experience on the subject, has any suggestions.
  5. millsey
    millsey New Member
    Dec 21, 2011
    203
    Setting an inbound rule to send a fax to the email of a user is working.
