Cannot get bridge between two 3CX systems to register
Discussion in '3CX Phone System - General' started by runnerpaul, Aug 5, 2015.
  1. runnerpaul
    Nov 22, 2013
    25
    I tried to create a bridge between two offices. I've configured my master and slave but neither will register.
    My logs show the following error:
    Can anybody advise why this might be the case?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,321
    253
    So the ID and Password on both ends correct I assume?
    Can you show verbose log - or is that it?
  3. runnerpaul
    Nov 22, 2013
    25
    Here you go. It doesn't look any different.
    The password is correct on both ends. I'm not 100% sure what the ID is. Where can I check this?
    Also, could this be related to ports that aren't open or need port forwarding enabled?
  4. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,099
    166
    Did you follow these instructions ? http://www.3cx.com/docs/connecting-offices-bridges/
  5. way
    way
    Feb 21, 2011
    49
    Have you set the virtual extension numbers at both sites the same? This is what is used as the ID for authentication and would produce that error.
