Cannot get VOIP provider SIPGATE to register
Discussion in '3CX Phone System - General' started by sparticle, Mar 27, 2008.
  1. sparticle
    Mar 27, 2008
    02080999xxx Line No: 02080999xxx
    Status: Not registered
    22:47:35.124 ClientRegs::eek:nFailure [CM504005]: Registration failed for: 02080999xxx@SIPGATE02080999xxx; Cause: 408 Request Timeout; internal
    22:47:28.835 ClientRegs::Register [CM504003]: Sent registration request for 02080999xxx@SIPGATE02080999xxx
    Followed all guides etc. cannot make this work, if I dial my nunber from PSTN or a mobile it comes up as number not in use.
    Can anyone help with SIPGATE configuration?
    Cheers
    Stephen
  2. h2009
    h2009 Member
    Mar 15, 2008
    447
    Have you checked your fireware, are all the ports open?
    List the ports which you have open and i'll check them over for you.
  3. MajoR_Mess
    Dec 4, 2007
    11
    A message saying number not in use on a PSTN network would indicate that u have the wrong number, or Sipgate have not set up the DID properly.
    A simple test would be to enable Sipgates voicemail, disconnect the 3cx server from sipgate, then call the number and see if it goes to voicemail.
