Cannot hear Auto Attendant
Discussion in '3CX Phone System - General' started by mauriceatkinson, Oct 17, 2008.
  1. mauriceatkinson
    Oct 17, 2008
    I wonder if someone can help me.
    I have the freebie version of 3CX and have setup the auto attendant to answer each incoming call and route the the relevent extension. However when I have a problem as although AA answers the incoming call I cannot hear any audio. I press the relevent dtmf key and I then hear the AA saying "please wait while call is transferred" and the call gets transferred OK.
    I have looked at the logs and there is no apparent error messages.
    I have listened to the audio file using windows media player and all works OK.
    The server I have loaded 3CX does not have windows media player loaded - not sure if this is required or not.
    Would appreciate some assistance if possible.
  2. cyberlex7
    Jul 12, 2008
    19
    Are you sure that you have respected correct audio file format ?
    I had this problem because bitrate was too high.
    Plase tell us whtat is your exact wav file format
    Regards,
    Alex.
  3. worksighted
    worksighted New Member
    Aug 19, 2008
    204
    I have had issues with recodirng WAV files and having them play back properly. Here is my trick to make sure 3CX is happy with the file ...
    I create a dummy extension and register a phone to it. I then use my "voicemail" message to provide me the ability to record my DR prompts. In other words, I call in and record my personal voicemail message as whatever the DR prompt needs to be. I then go into the IVR directory inside 3CX and grab the WAV file it records and use that for the WAV file needed by the DR.
    I have had much better luck doing it this way.
    Mike
