Cannot Hear me, No Outgoing Voice
Discussion in '3CX Phone System - General' started by simongare@yahoo.co.uk, Jun 19, 2007.
  1. simongare@yahoo.co.uk
    Jun 19, 2007
    can receive and hear inbound calls but they cannot hear me !!
    Any ideas
    Using Grandstream GX2000 phone.
    Regards
    Simon
  2. Anonymous
    Anonymous Guest
    Check:
    - codecs
    - firewall Make sure ports are open
    - Set extension to be external
    With they is that an extension on the PBX or is it an external number?
    Bit more info,
    (funny enough I get a lot of mails about this at the moment).
  3. simongare@yahoo.co.uk
    Jun 19, 2007
    checklist complete, ports 9000-9003 open, extension is on PBX not external but still no voice going through only incoming?
    Any ideas.
    Regards
    Simon
  4. Borsoock
    Borsoock New Member
    Apr 8, 2007
    149
    Check if STUN is configured properly and actually working :).
    Marcin
  5. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    STUN works properly, because incoming audio works. There can be issues related to VoIP provider "features" or network (VoIP provider) problems on the other side of call.
    It is difficult to find a reason without any information...
    Regards,
    Stepan
  6. simongare@yahoo.co.uk
    Jun 19, 2007
    LOG FILE ERROR
    Hi below server status report
    16:47:22.218 MediaServerReporting::RTPReceiver from 'demo:0/MediaServer':No RTP packets were received on 00000019@:remoteAddr=192.168.1.14:5004,extAddr=0.0.0.0:0,localAddr=169.254.2.2:7022
    IP of phone 192.168.1.14
    IP of PC running 3cx 192.168.1.25
    No firewall on machine just on router.
    Any Ideas.
  7. SY
    3CX Support
    Jan 26, 2007
    1,825
    Re: LOG FILE ERROR
    Upgrade your software. New version is available since Sunday :)
    192.168.1.14:5004 - is local address that cannot be reachable from your network. Configure remote party correctly ;)
    "IP of PC running 3cx 192.168.1.25" information is not correct, because of "...,localAddr=169.254.2.2:7022"
  8. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    If your GXP-2000 and your PBX at same LAN. Please try to diable the STUN at GXP-2000. Where the option at account X. At NAT Traversal (STUN) select No. Then click Update => reboot.
    See it works or not.
    We have few GXP-2000 at LAN or over NAT are work fine.
    Our FW version: Program 1.1.1.14 Bootloader 1.1.1.5
  9. ebiemans
    Jun 18, 2007
    Just enter a fake address in the default STUN address field so the PBX cannot register a default STUN then it works.
