Cannot install version 8
Discussion in '3CX Phone System - General' started by sipero123, Oct 6, 2009.
  1. sipero123
    Nov 24, 2008
    94
    One of my clients has just tried to install the new version 8 released today as a clean install but get this. Any ideas?
    "There is a problem with this Windows Installer package. A script required for the install to complete could not be run. Contact your support personnel or vendor".
    Jonathan Hamon
  2. smb1
    smb1 New Member
    Mar 18, 2009
    104
    I received the same error message.
    Make sure you have installed .Net Framework 2.0 Service Pack 1 from
    http://www.microsoft.com/downloads/info.aspx?na=90&p=&SrcDisplayLang=en&SrcCategoryId=&SrcFamilyId=79bc3b77-e02c-4ad3-aacf-a7633f706ba5&u=http%3a%2f%2fdownload.microsoft.com%2fdownload%2f0%2f8%2fc%2f08c19fa4-4c4f-4ffb-9d6c-150906578c9e%2fNetFx20SP1_x86.exe
    Or search on http://microsoft.com/downloads for ".Net Framework" to find it if the URL does not work.
    David Benet
    SMB Technology
    Melbourne, Australia
  3. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    http://www.3cx.com/forums/3cx-installation-errors-on-vista-server-2008-windows-11512.html
  4. csantos
    Nov 15, 2009
    smb1,
    Thanks for the help. The issue is resolved !
