Cannot Install
Discussion in '3CX Phone System - General' started by implitech, Jul 19, 2011.
  1. implitech
    Jul 19, 2011
    That is error i am getting.
    how do I fix it?
    I tried installing version 9 and 10! I get this error.
    I am on windows XP SP3 With latest .net and installer version 4.5
  2. varietel
    Oct 29, 2010
    22
    I was getting the same error message on a XP machine and upgrading to SP2 and the latest .net fixed the problem. Make sure you have saved the 3CX .exe file on the PC that you are installing. That is you are not installing from a USB drive.
    Good Luck.
    Roger Partovi
    Varietel Communications
    Certified 3CX partner
    801-889-1414
  3. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Install .NET 3.5 and it will install
