Cannot load provisioning template
Discussion in '3CX Phone System - General' started by justin, Apr 7, 2009.
  1. justin
    Feb 20, 2008
    79
    I have server 2003 setup with 3cx 7 running on it utilising the built in IIS server, but I have a problem when I am attempting to use provisioning. I noticed the phones were not provisioning when setup to so I chucked the URL into a web browser to check it was loading correctly and I would get 1 of 2 errors:
    Error: HTTP 403 Forbidden
    URL: http://X.X.X.X/management/provisioning
    Error: HTTP Error 404 - File or directory not found
    URL: http://X.X.X.X/management/provisioning/{template name}.xml
    Any idea how to correct this???
  2. justin
    Feb 20, 2008
    79
    Has anyone used provisioning with IIS and know how to fix this???
  3. mbaltus
    Dec 12, 2008
    66
    Do you have a registered version of 3CX, I believe that provisioning is only possible with the paid versions. For testing you can request a demo key allowing all functionality but limiting to 1 or 2 outside lines.
    FYI: I use Windows 2008 32-bit (UK) with IIS7 and provisioning of around 25 Linksys SPA942 phones. I have added many features to the default provisioning template delivered with the system to set a lot of extra options (including time-settings, password protect the web management intf., a few BLF keys, language settings, display settings, etc.).
    ---> Re-reading your post; do you mean you use IIS or Cassini (the bundled webserver)
