Cannot login to Assistant
Discussion in '3CX Phone System - General' started by WRZHost.com, Dec 2, 2009.
  1. WRZHost.com
    Dec 2, 2009
    I have created the new server, put the software on it, with the skype addon. Now I am trying to setup the switchboard. I tried to login, but the client times out every time. I have created other users still will not login, even as local host.
    both PCs have their firewalls disabled. Can anybody take a look or advise on whats going on?
    Ben
  2. WRZHost.com
    Dec 2, 2009
    Right, I not have half solved it, I can login but I cannot register the agent.
    How do I do this, I have tried everything :(
  3. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    Verify that Assistant Service on the server is running. If not, install Net Framefork 3.5 SP1 and run it manually.
