Cannot login to MyPhone
Discussion in '3CX Phone System - General' started by muaddib32, Oct 2, 2011.
  1. muaddib32
    Oct 16, 2010
    68
    I have just upgraded to v10 and find that I cannot login to MyPhone as any extension (I have tried five different). I have checked and the login details are correct, they work when used to connect a phone.
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    how are you trying to login? are you using the extension number and PIN (PIN = voicemail PIN) and not authentication password.
    Thanks,
    Nate
  3. muaddib32
    Oct 16, 2010
    68
    Wow, that's incredibly logical. And consistent with the 3CX assistant. NOT!! Since I don't have voicemail enabled on any extension, I have had to enable it, create a PIN, then disable it again.
  4. nbailey
    nbailey Member
    Jan 31, 2011
    359
    you did notice it asked for a PIN and not authentication password? it has been this way since MyPhone was introduced to V10 at the start. There is nothing there to say otherwise.
