Solved Cannot logon to the Management Console
Discussion in '3CX Phone System - General' started by Mathias Frans, May 26, 2017.
  1. Mathias Frans
    May 26, 2017
    7
    Hi i installed the 3CX V15 Linux version
    after i loged off i tried to relogin with my account and password now it's giving me server error
    the credentials are correct because i can login true a 4G network
    I already checked if my IP is blacklisted and it's not
    Also my Time and Date is wrong it's set to Brussels GTM +1 but it's telling me that it's 15-01-2017 1:25...
    it's a verry urgent issue because this is my thesis and i need to show it next week..
  2. Hello @Mathias Frans
    Have you tried to clear your browser cache or open on incognito mode?
  3. Mathias Frans
    May 26, 2017
    7
    hello @3CXZacharias thanks in advantage
    yeah i already tried this also tried another browser and tried another pc
  4. agp
    agp 3CX Team
    Aug 19, 2015
    150
    22
    Please make sure that all 3CX services are running.
    What is the output of the following command? :
    Code:
    service 3CXPhoneSystemMC01 status
  5. Mathias Frans
    May 26, 2017
    7
    @agp if i open the site true my smartphone everything works if i open it on my computer(s) true wifi of 4G its giving the same error
    already tried restoring a backup
    the output is in the attachment
    i had the same issue a few months ago and it resolved itself but now i doesent..
    also tried apt-get update / apt-get upgrade
    also updatet to the latest 3CX
  6. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,551
    298
    So phone works on 4G but Computer on WiFi does not work?
    This is a DNS issue.
    What web address are you trying to use to logon to?
  7. Mathias Frans
    May 26, 2017
    7
    If i try to log in on
    my3cx.be:5000
    https:/ /my3cx.be:5001
    or my internal ip x.x.x.x:5000
    i get the login page but after i click sign in i get server error, but if i try the same with the same login tru my cellphone's webbrowser on 4G it logs in.
  8. agp
    agp 3CX Team
    Aug 19, 2015
    150
    22
    Your computer is connected to 4G via wifi? Is that correct? Which means both the computer and the smartphone share the same Internet Connection?
    Try the following:
    Open the command prompt on your computer as administrator and run:
    Code:
    ipconfig /flushdns
    Open the Management Console in Chrome, press F12, Navigate to the "Network" tab and click "Disable cache".
    Now try accessing the Management Console while the Developer Tools console is open and see if that makes any difference.
    Mathias Frans likes this.
  9. Mathias Frans
    May 26, 2017
    7
    this works !! after disabling the cache i can log in, how can i resolve this issue ?
  10. agp
    agp 3CX Team
    Aug 19, 2015
    150
    22
    Im glad it has worked for you. I have marked this topic as solved (only moderators can do so).
