Cannot make any ouside call
Discussion in '3CX Phone System - General' started by abitec, Aug 15, 2013.
  1. abitec
    Nov 6, 2012
    11
    I try configure FREE Edition as demo for customer, but I have problem make any outside call to internal extensions. Internal extensions between communicate OK.
    In the log I have this info :
    15-8-2013 17:05:21.056 L:4.1[Line:10000<<903722781]: Terminating targets, reason:
    15-8-2013 17:05:21.056 Leg L:4.1[Line:10000<<903722781] is terminated: Cause: BYE from PBX
    15-8-2013 17:05:21.056 L:4.1[Line:10000<<903722781] Sending: OnSendReq Send Req BYE from 0.0.0.0:0 tid=2608364b5b0d5c73 Call-ID=5329c33335954f3a368fa5460f86bbf7@80.79.25.251:
    BYE sip:903722781@80.79.25.251 SIP/2.0
    Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-2608364b5b0d5c73-1---d8754z-;rport
    Max-Forwards: 70
    Contact: <sip:0333000002@87.197.117.21:5060>
    To: "903722781"<sip:903722781@80.79.25.251>;tag=as6d907d44
    From: <sip:0333000002@87.197.117.21:5060>;tag=746fd003
    Call-ID: 5329c33335954f3a368fa5460f86bbf7@80.79.25.251
    CSeq: 2 BYE
    Content-Length: 0
    15-8-2013 17:05:21.055 L:4.1[Line:10000<<903722781]: Terminating targets, reason: SIP ;cause=200 ;text="Call terminated on user request"
    15-8-2013 17:05:12.653 Session 99 of leg L:4.1[Line:10000<<903722781] is confirmed
    11,111
    329
    I take it you are using a VoIP provider? Which one? That can make a difference as some are supported and some require some tweaks to work.
    Does the VoIP trunk show as registered? Have you created proper outbound rules? Sending the correct digits?
    You left out the first part of the call, from where t was first dialled, showing which outbound rule it used.
