Cannot make calls through SIP trunk provider
Discussion in '3CX Phone System - General' started by sergiop, Jun 18, 2010.
  1. sergiop
    Jun 18, 2010
    I configured a Genric SIP trunk. I received calls OK but I get FORBIDDEN message when try to make calls.
    My 3CX PBX cannot make calls throug SIP TRUNK because we are not sending the right information to my SIP provider in the CONTACT and FROM SIP fields.
    MY ip address is 10.10.1.1
    My Phone number is 600 0000
    My Provider host ip address is 10.0.0.2
    MY provider is requesting for the following information:
    Contact: <sip:6000000@10.10.1.1>
    From: "company"<sip:6000000@10.10.1.1>>;tag=14287a0d
    My 3CX is sending
    INVITE sip:28890900@10.0.0.2:5060 SIP/2.0
    Via: SIP/2.0/UDP 10.222.3.2:5060;branch=z9hG4bK-d8754z-f10298361308f964-1---d8754z-;rport
    Max-Forwards: 70
    Contact: <sip:0.0.0.0:5060>
    To: <sip:28890900@10.0.0.2:5060>
    Call-ID: MGQyMGY5NDhkMzVkZDBkMmEyOTNkZjFiYjc3YjdkNTE
    Could anyone tellme how can I change this values?
    Regards,
    Sergio Pombo
    11,293
    361
    The IP address you've shown do not appear to be valid Public IPs. You can confirm that using a service such as this...http://baremetal.com/cgi-bin/dnsip
    Your provider should have a URL (most common) or a Public IP address. If you datafill the trunk information in 3CX correctly, the trunk will show that it is registered. That registration process (and any failures) will show up in the 3CX logs when you first start (or re-start 3CX).
  3. sergiop
    Jun 18, 2010
    Yes, this is not a public IP but that is because my provider uses an extranet just to connect to them with a dedicated channel. Connectivity wise is working ok and this is not the issue. I need to find out how to make 3CX send the righ information to the provider.
    Thanks ....
