Cannot make dummy ext to forward to park in v15?**[FIXED]
Discussion in '3CX Phone System - General' started by jbryant84, Jul 28, 2016.
  1. jbryant84
    jbryant84 New Member
    Apr 6, 2016
    109
    40
    Historically we have created a dummy extension that has a mobile number set to the shared park extension (501 is SP1, 501 SP2 etc) and the forwarding rules set that when an extension is unregistered it sends the call to the mobile number. This is good for use with analog phones, and for sending calls across a bridge to the other 3CX shared parks.
    This functionality seems to be broken in v15. Is there another way that this can be accomplished?
      File size:
      4.6 KB
      502
  2. jbryant84
    Apr 6, 2016
    109
    40
    Re: Cannot make dummy ext to forward to park in v15?
    Figured it out. Safe to delete post.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,530
    298
  4. giwm
    giwm New Member
    Sep 27, 2016
    246
    42
    @jbryant: Did you get this working with v15 sp4? I can't put alphabetic characters in those fields.
    craigreilly likes this.
  5. craigreilly
    Feb 1, 2012
    3,530
    298
    would like to know too... the only way I have heard is to
    send invite of dummy SPx extension to admin.
    import config into softphone.
    setup forwarding in softphone.
    done.
