- Joined
- Mar 28, 2008
- Messages
- 5
- Reaction score
- 0
All of a sudden my pstn line just stopped working. When I call it I get a disconnected message and when I try to call FROM it I get a series of error messages. Here is the log below of when I am trying to make a call from this phone. On the on screen display it shows call failed Reason Code 480.
13:43:23.908 Call::Terminate [CM503008]: Call(6): Call is terminated
13:43:23.877 Call::RouteFailed [CM503014]: Call(6): Attempt to reach [sip:[email protected]] failed. Reason: Not Registered
13:43:23.877 CallCtrl:nSelectRouteReq [CM503015]: Call(6): Target is not registered: PSTNline:15617072133 dialed on (AnyLine@Cox Line)
13:43:23.877 Line::Line [CM303003]: There are no available outbound lines on gateway Cox Line at this time.
13:43:23.862 CallCtrl:nSelectRouteReq [CM503010]: Making route(s) to [sip:[email protected]]
13:43:23.862 MediaServerReporting::SetRemoteParty [MS210000] C:6.1:Offer received. RTP connection: 192.168.1.214:5004(5005)
13:43:23.862 CallLeg::setRemoteSdp Remote SDP is set for legC:6.1
13:43:23.862 Extension:rintEndpointInfo [CM505001]: Ext.104: Device info: Device Identified: [Man: GrandStream;Mod: GXP-2000;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.1.5.15] Transport: [sip:192.168.1.11:5060]
13:43:23.815 CallCtrl:nIncomingCall [CM503001]: Call(6): Incoming call from Ext.104 to [sip:[email protected]]
13:43:23.815 CallLeg:nNewCall [CM500002]: Info on incoming INVITE:
INVITE sip:[email protected] SIP/2.0
Via: SIP/2.0/UDP 192.168.1.214:5060;branch=z9hG4bK3e979e9702ee6b60
Max-Forwards: 70
Contact: [sip:[email protected]:5060;transport=udp]
To: [sip:[email protected]]
From: "Richard Ecker"[sip:[email protected]];tag=ea2353f561f52497
Call-ID: [email protected]
CSeq: 55930 INVITE
Allow: INVITE, ACK, CANCEL, BYE, NOTIFY, REFER, OPTIONS, INFO, SUBSCRIBE, UPDATE, PRACK, MESSAGE
Proxy-Authorization: Digest username="104",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:[email protected]",nonce="12903475403:1a272752c43bb47954abed7b9593ed98",response="815855e22bf97fbbf96f95562d1b0c8d"
Supported: replaces, timer, path
User-Agent: Grandstream GXP2000 1.1.5.15
Content-Length: 0
I am using grandstream phones and a linksys spa3102 device for the line. Any ideas?
Here is some further information since trying it again...
Call::Terminate [CM503008]: Call(8): Call is terminated
13:48:49.065 Call::RouteFailed [CM503014]: Call(8): Attempt to reach [sip:[email protected]] failed. Reason: Server Failure
13:48:49.065 CallLeg:nFailure [CM503003]: Call(8): Call to sip:[email protected]:5061 has failed; Cause: 503 Service Unavailable; from IP:192.168.1.33:5061
13:48:49.033 MediaServerReporting::SetRemoteParty [MS210006] C:8.2:Offer provided. Connection(by pass mode): 192.168.1.214:5004(5005)
13:48:49.018 CallCtrl:nSelectRouteReq [CM503004]: Call(8): Calling: PSTNline:10002@[Dev:sip:[email protected]:5061]
13:48:49.002 CallCtrl:nSelectRouteReq [CM503010]: Making route(s) to [sip:[email protected]]
13:48:49.002 MediaServerReporting::SetRemoteParty [MS210000] C:8.1:Offer received. RTP connection: 192.168.1.214:5004(5005)
Max-Forwards: 70
CSeq: 55930 INVITE
Content-Length: 0
