Cannot make outbound calls
Discussion in '3CX Phone System - General' started by ellenboa, Apr 16, 2010.
  1. ellenboa
    Apr 16, 2010
    5
    I just installed and configured 3CX phone system. I have setup my VoIP provider as Call Centric.
    I am using the 3CX softphone for now while i get my configuration all squared away.
    My problem: I can receive inbound calls just fine. It rings, it answers, quality is great. I call from my cell phone and there is very little delay/latency too, i love it. I cannot make an outbound call. I dial the number, 3CX software just sits for a moment, then returns to a phone "on hook" state.
    I followed instructions from Call Centric to setup my inbound and outbound rules.
    I hope to figure this out ASAP. Thanks in advance for help.
  2. pcunite
    Apr 12, 2010
    29
    You need to set up an outbound rule.
    * Add Outbound Rule
    * Give it a name
    * Set "Calls to Numbers with a lengh of" to "7"
    * Set Route 1, click the drop down and choose your provider, Set "Strip Digits" to 0, and then "PrePend" to 1 and your area code.
  3. ellenboa
    Apr 16, 2010
    5
    Thanks. I tried this and it didn't work at first. Just as i was getting ready to post that i still could not make an outbound call, it began working properly.
    Thanks for your help, and quick too. I had assumed that not too many people look around these forums regularly.
  4. leejor
    10,366
    228
    That rule is fine for local numbers but you will probably want a more encompassing rule(s) to cover both local and long distance (more than one area code), and perhaps overseas.
