Cannot make outgoing calls.
Discussion in '3CX Phone System - General' started by raywesner, Aug 20, 2014.
  1. raywesner
    Jun 18, 2014
    I am using the SPA-3102 and up until today, I was able to make outgoing calls. I am not sure if I messed something up making changes, or if something happened on its own. Incoming calls work fine, but now when I dial (9) then the # on the phone it says invalid number (I am using cisco spa 303 phones. I have my dial plan set to access the outside line (SPA3102) and you must press 9 to dial out, and it strips 1 digit.
    Here is a copy and paste from the server log:
    19-Aug-2014 22:35:56.759 Leg L:4.1[Extn] is terminated: Cause: BYE from PBX
    19-Aug-2014 22:35:56.709 [CM503020]: Call(C:4): Normal call termination. Call originator: Extn:104. Reason: Not found
    19-Aug-2014 22:35:56.708 L:4.1[Extn] failed to reach Line:10000>>6933262, reason Not Found
    19-Aug-2014 22:35:56.708 Leg L:4.2[Line:10000>>6933262] is terminated: Cause: 404 Not Found/INVITE from 192.168.1.250:5060
    19-Aug-2014 22:35:56.708 Call to T:Line:10000>>6933262@[Dev:sip:10000@192.168.1.250:5062] from L:4.1[Extn] failed, cause: Cause: 404 Not Found/INVITE from 192.168.1.250:5060
    19-Aug-2014 22:35:56.707 [CM503003]: Call(C:4): Call to <sip:6933262@192.168.1.250:5060> has failed; Cause: 404 Not Found/INVITE from 192.168.1.250:5060
    19-Aug-2014 22:35:56.646 [CM503025]: Call(C:4): Calling T:Line:10000>>6933262@[Dev:sip:10000@192.168.1.250:5062] for L:4.1[Extn]
    19-Aug-2014 22:35:56.598 [CM503027]: Call(C:4): From: Extn:104 ("104" <sip:104@192.168.1.130:5060>) to T:Line:10000>>6933262@[Dev:sip:10000@192.168.1.250:5062]
    19-Aug-2014 22:35:56.598 [CM503004]: Call(C:4): Route 1: from L:4.1[Extn] to T:Line:10000>>6933262@[Dev:sip:10000@192.168.1.250:5062]
    19-Aug-2014 22:35:56.598 Line limit check: Current # of calls for line Lc:10000(@SPA3102[<sip:10000@192.168.1.250:5062>]) is 0; limit is 1
    19-Aug-2014 22:35:56.598 Call(C:4): Call from Extn:104 to 96933262 matches outbound rule 'Rule for SPA3102'
    19-Aug-2014 22:35:56.596 [CM503001]: Call(C:4): Incoming call from Extn:104 to <sip:96933262@192.168.1.130:5060>
    19-Aug-2014 22:35:09.505 [CM504010]: Fax Service: Fax.888 unregistered contact sip:888:5100;user=phone
    19-Aug-2014 22:35:07.934 [EC100007]: External application [PhoneSystemFD:0/QueueManager] is disconnected:
    19-Aug-2014 22:35:07.498 [EC100006]: Connection with Conference server is lost
    19-Aug-2014 22:32:55.211 Leg L:3.1[Extn] is terminated: Cause: BYE from PBX
    19-Aug-2014 22:32:55.161 [CM503020]: Call(C:3): Normal call termination. Call originator: Extn:104. Reason: Not found
    19-Aug-2014 22:32:55.160 L:3.1[Extn] failed to reach Line:10000>>6933262, reason Not Found
    19-Aug-2014 22:32:55.160 Leg L:3.2[Line:10000>>6933262] is terminated: Cause: 404 Not Found/INVITE from 192.168.1.250:5060
    19-Aug-2014 22:32:55.160 Call to T:Line:10000>>6933262@[Dev:sip:10000@192.168.1.250:5062] from L:3.1[Extn] failed, cause: Cause: 404 Not Found/INVITE from 192.168.1.250:5060
    19-Aug-2014 22:32:55.159 [CM503003]: Call(C:3): Call to <sip:6933262@192.168.1.250:5060> has failed; Cause: 404 Not Found/INVITE from 192.168.1.250:5060
    19-Aug-2014 22:32:55.105 [CM503025]: Call(C:3): Calling T:Line:10000>>6933262@[Dev:sip:10000@192.168.1.250:5062] for L:3.1[Extn]
    19-Aug-2014 22:32:55.057 [CM503027]: Call(C:3): From: Extn:104 ("104" <sip:104@192.168.1.130:5060>) to T:Line:10000>>6933262@[Dev:sip:10000@192.168.1.250:5062]
    19-Aug-2014 22:32:55.057 [CM503004]: Call(C:3): Route 1: from L:3.1[Extn] to T:Line:10000>>6933262@[Dev:sip:10000@192.168.1.250:5062]
    19-Aug-2014 22:32:55.056 Line limit check: Current # of calls for line Lc:10000(@SPA3102[<sip:10000@192.168.1.250:5062>]) is 0; limit is 1
    19-Aug-2014 22:32:55.056 Call(C:3): Call from Extn:104 to 96933262 matches outbound rule 'Rule for SPA3102'
    19-Aug-2014 22:32:55.054 [CM503001]: Call(C:3): Incoming call from Extn:104 to <sip:96933262@192.168.1.130:5060>
    19-Aug-2014 22:32:14.889 Leg L:2.2[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 192.168.1.104:5060
    19-Aug-2014 22:32:14.889 [CM503003]: Call(C:2): Call to <sip:104@192.168.1.130:5060> has failed; Cause: 487 Request Terminated/INVITE from 192.168.1.104:5060
    19-Aug-2014 22:32:14.780 [CM503008]: Call(C:2): Call is terminated
    19-Aug-2014 22:32:14.778 Leg L:2.1[Line:10000<<7176933262] is terminated: Cause: CANCEL from 192.168.1.250:5062
    19-Aug-2014 22:32:06.088 [CM503025]: Call(C:2): Calling T:Extn:104@[Dev:sip:104@192.168.1.104:5060] for L:2.1[Line:10000<<7176933262]
    19-Aug-2014 22:32:06.047 [CM503027]: Call(C:2): From: Line:10000<<7176933262 ("PENNSYLVANIA" <sip:7176933262@192.168.1.130:5060>) to T:Extn:104@[Dev:sip:104@192.168.1.104:5060]
    19-Aug-2014 22:32:06.047 [CM503004]: Call(C:2): Route 1: from L:2.1[Line:10000<<7176933262] to T:Extn:104@[Dev:sip:104@192.168.1.104:5060]
    19-Aug-2014 22:32:06.044 [CM505002]: Gateway:[SPA3102] Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.2.13(GW002)] PBX contact: [sip:10000@192.168.1.130:5060]
    19-Aug-2014 22:32:06.042 [CM503001]: Call(C:2): Incoming call from Line:10000<<7176933262 to <sip:104@192.168.1.130:5060>
    19-Aug-2014 22:32:06.040 Line limit check: Current # of calls for line Lc:10000(@SPA3102[<sip:10000@192.168.1.250:5062>]) is 1; limit is 1
    19-Aug-2014 22:32:06.034 [CM503012]: Inbound office hours rule (unnamed) for 10000 forwards to DN:104
    19-Aug-2014 22:30:49.663 Leg L:1.1[Extn] is terminated: Cause: BYE from PBX
    19-Aug-2014 22:30:49.612 Leg L:1.2[Line:10000>>6933262] is terminated: Cause: 404 Not Found/INVITE from 192.168.1.250:5060
    19-Aug-2014 22:30:49.612 [CM503020]: Call(C:1): Normal call termination. Call originator: Extn:104. Reason: Not found
    19-Aug-2014 22:30:49.612 L:1.1[Extn] failed to reach Line:10000>>6933262, reason Not Found
    19-Aug-2014 22:30:49.612 Call to T:Line:10000>>6933262@[Dev:sip:10000@192.168.1.250:5062] from L:1.1[Extn] failed, cause: Cause: 404 Not Found/INVITE from 192.168.1.250:5060
    19-Aug-2014 22:30:49.611 [CM503003]: Call(C:1): Call to <sip:6933262@192.168.1.250:5060> has failed; Cause: 404 Not Found/INVITE from 192.168.1.250:5060
    19-Aug-2014 22:30:49.553 [CM503025]: Call(C:1): Calling T:Line:10000>>6933262@[Dev:sip:10000@192.168.1.250:5062] for L:1.1[Extn]
    19-Aug-2014 22:30:49.516 [CM503027]: Call(C:1): From: Extn:104 ("104" <sip:104@192.168.1.130:5060>) to T:Line:10000>>6933262@[Dev:sip:10000@192.168.1.250:5062]
    19-Aug-2014 22:30:49.516 [CM503004]: Call(C:1): Route 1: from L:1.1[Extn] to T:Line:10000>>6933262@[Dev:sip:10000@192.168.1.250:5062]
    19-Aug-2014 22:30:49.515 Line limit check: Current # of calls for line Lc:10000(@SPA3102[<sip:10000@192.168.1.250:5062>]) is 0; limit is 1
    19-Aug-2014 22:30:49.515 Call(C:1): Call from Extn:104 to 96933262 matches outbound rule 'Rule for SPA3102'
    19-Aug-2014 22:30:49.513 [CM503001]: Call(C:1): Incoming call from Extn:104 to <sip:96933262@192.168.1.130:5060>
    19-Aug-2014 22:28:51.396 [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 192.168.1.250:5062 tid=-b61a1079 Call-ID=643e66f4-aa76d850@192.168.1.250:
    REGISTER sip:192.168.1.130 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.250:5062;branch=z9hG4bK-b61a1079
    Max-Forwards: 70
    Contact: "SPA"<sip:10000@192.168.1.250:5062>;expires=3600
    To: "SPA"<sip:10000@192.168.1.130>
    From: "SPA"<sip:10000@192.168.1.130>;tag=6b5216606fc31153o1
    Call-ID: 643e66f4-aa76d850@192.168.1.250
    CSeq: 46762 REGISTER
    Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
    Proxy-Authorization: Digest username="10000",realm="3CXPhoneSystem",nonce="414d535c0a0498e307:6adc21201542c3d400a364d02e5a1fb4",uri="sip:192.168.1.130",algorithm=MD5,response="744f40c741eb8466d86fcac727bcbb74"
    Supported: x-sipura, replaces
    User-Agent: Linksys/SPA3102-5.2.13(GW002)
    Content-Length: 0
    Someone please help!!
    I will be forever greatfull
    Ray
    10,586
    252
    What I find odd here is that there are two ports on the same IP. I have to assume that port 5062 is used by the gateway portion, but the other port 5060 (same IP) does not appear to be the FXS port on the 3102, which I assume it would be. What is the IP of the 3CX server, 192.168.1.250 ? Hmmmm
    You may want to confirm what IP you have the 3102 set to, I assume it is a fixed IP, and, what IP you have the trunk set-up in 3CX "pointing" to.
  3. raywesner
    Jun 18, 2014
    The 3102 is at a static I.P. : 192.168.1.250
    The VoIP/PSTN Gateway is pointing to 192.1686.1.250
    In the SPA3102 I followed the instuctions and set up the Line 1 tab and the PSTN line tab. I have them both configured. The line tab is the 5060 that you see, the pstn line is the 5062.
    The problem might be that I should not have them both active??
    I am kind of new to all this.
    Thanks,
    Ray
