CANNOT MAKE OUTGOING PHONE CALLS WITH PATTON 4634
Discussion in '3CX Phone System - General' started by luppazzo, Apr 17, 2008.
  1. luppazzo
    Apr 17, 2008
    Hi all
    set up is a 3CX with VOIP provider and 3 Telecom ISDN lines. All incoming and outoing calls with the VOIP provider are OK
    also incoimng calls through TELECOM and PATTON 4634 are OK
    the problem is when making outgoing calls the log says:
    17:56:00.000 Call::Terminate [CM503008]: Call(60): Call is terminated
    17:55:59.968 Call::RouteFailed [CM503014]: Call(60): Attempt to reach [sip:049652653@192.168.0.2] failed. Reason: Not Found
    17:55:59.968 CallLeg::eek:nFailure [CM503003]: Call(60): Call to sip:049652653@192.168.0.7:5060 has failed; Cause: 404 Not Found; from IP:192.168.0.7
    17:55:59.859 CallLeg::eek:nFailure [CM503003]: Call(60): Call to sip:049652653@192.168.0.7:5060 has failed; Cause: 404 Not Found; from IP:192.168.0.7
    17:55:59.812 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(60): Calling: PSTNline:10001@[Dev:sip:10001@192.168.0.7:5060, Dev:sip:10002@192.168.0.7:5060]
    17:55:59.781 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:049652653@192.168.0.2]
    17:55:59.765 Extension::printEndpointInfo [CM505001]: Ext.206: Device info: Device Identified: [Man: GrandStream;Mod: GXP-2000;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.1.5.15] Transport: [sip:192.168.0.2:5060]
    17:55:59.750 CallCtrl::eek:nIncomingCall [CM503001]: Call(60): Incoming call from Ext.206 to [sip:049652653@192.168.0.2]
    anyone can help with this?
    thank you
