"Perform operations" is the 'rights' to control "visible" calls. If you disable user to see calls, the user does not have any subjects to perform operations.kosath said:It says *20* - also all phones have the *20* configured to quickdial button... when an extension of the same group rings I dial *20* or press the quick dial button and the screen says "Not found" (yealink t20).
User group rights:
Can see group members: yes
can see group calls: no
show presence to group members: yes
show calls to group members: yes
perform operations... : yes
can barge in: no
can intercom: no
allow parking: yes
allow ivr control: no
allow users to show... : no
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
