cannot preend (*)
Discussion in '3CX Phone System - General' started by akourou, Jul 11, 2009.
  1. akourou
    Oct 20, 2008
    10
    I need to create a outbound rule that prepends the star (*) character.
    I created a rule that dials calls to Numbers starting with (Prefix) 4
    then stripe 1 digit and preend *31*
    for example:
    I dial 4 210 8080808
    and I expect it to dial *31*210 8080808
    is this possible?
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    hello,
    when you add route, you can delete first number -> 4 and add number *31*. do you try this ?
    check if your rule is on first place.
  3. akourou
    Oct 20, 2008
    10
    yes that is what I did, but my spa942 displays "forbidden" and I hear busy tone...
