Cannot proceed with installation on Linux Debian
Discussion in '3CX Phone System - General' started by Federico Moschini, Jun 16, 2017.
  1. Federico Moschini
    Jan 6, 2017
    31
    Dear 3cx team today I tried to do a freh installation but not working as below screenshot.
    Any suggestion?
  2. agp
    agp 3CX Team
    Aug 19, 2015
    151
    22
    Hi @Federico Moschini ,
    Please try copying the code in notepad first and then copy it from there to putty. (I recommend doing this every time you need to use any code found on the internet).
    Code:
    wget -O- http://downloads.3cx.com/downloads/3cxpbx/public.key | apt-key add -
    If successful (it should be) then run
    Code:
    echo "deb http://downloads.3cx.com/downloads/3cxpbx/ /" | tee /etc/apt/sources.list.d/3cxpbx.list
    apt-get update
    apt-get install 3cxpbx
