Cannot provision Snom 720 (manually or automatically)
Discussion in '3CX Phone System - General' started by alexanderbird, Jul 18, 2014.
  1. alexanderbird
    Jul 18, 2014
    5
    Configuring Snom 720 (Firmware version 8.7.3 ) with 3CX version 12
    Snom and 3CX documentation both say it’s compatible, with 3CX listing Snom as a preferred supplier.
    I have been unable to automatically or manually provision a Snom 720 phone.
    I set Option 66 as per guide: http://www.3cx.com/sip-phones/dhcp-option-66/
    Using the option: 3CX Phone system 12: http://192.168.3.155:5000/provisioning/%%ProvSubDir%%/cfg{mac}
    Shown below in the attached screenshot
    It still would not provision, showing the key hole and prompting to log in on the phone.
    From the phone’s web interface in the Advanced > Update tab I can see the settings_server points to snom.com but the update_server points to our server for the provisioning files.
    Still this wouldn’t load the provisioning file, and the phone showed a keyhole symbol with the message “Press any key to log in”.
    When we uploaded the file manually using the phone’s web interface and restarted, the phone got further than before, logged in, and showed the 3CX user. But, there was an error message:
    Prov. Server failed not registered: 3CX Phone ……
    The provisioning file is attached
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi, can you clarify firmware as you only said 8.7.3, are you running firmware version 8.7.3.25 (latest supported) ?
  3. alexanderbird
    Jul 18, 2014
    5
    Thanks for the quick response, and sorry about that. It's version 8.7.3.25.5
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hmm, that's a bit higher than the one we support, could you downgrade to 8.7.3.25 one of your handsets and see if same issue occurs on it please ?
  5. alexanderbird
    Jul 18, 2014
    5
    Hi again,
    I've downgraded to 8.7.3.25 and tried again. It seems to be working! I'll post again if there are any issues. Thanks for the help.
