Cannot Register Fax Extension
Discussion in '3CX Phone System - General' started by Steven.Zhang, Oct 26, 2017.
  1. Steven.Zhang
    Oct 16, 2017
    10
    Hello All,
    The fax and ATA are in a remote office , 3CX v15 system is in data center . The phones are connecting to phone system by SIP through internet line..
    I cannot register the ATA as fax extension , the error says Reason: Block WAN requests is ON. But the yealink SIP phones can be registered from same network.
    Could anyone help on this?
    11,095
    327
    I didn't think that remote Fax Extensions were supported without using VPN.
    YiannisH_3CX likes this.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,362
    535
    Hello @Steven.Zhang
    As leejor mentioned Fax extensions are only supported as local extensions. To register a FAX extension at a remote site you will need to establish a VPN connection between the remote site and the PBX. Normal extensions do support remote registration.
