Cannot register the 3CXPhone client on Windows 10
Discussion in 'Windows' started by gdurot, Sep 25, 2015.
  1. gdurot
    Sep 25, 2013
    5
    We have multiple computers on our network, all using the 3CXPhone for Windows client (version 12.0.33517.0).
    Everything is fine on all machines, except for the new Windows 10 machine (has all the latest updates) which cannot seem to register with the 3CX server, even though TCP/IP connectivity to the 3CX server is ok.
    Is there anything special to do with Windows 10?
    Thanks,
  2. gdurot
    Sep 25, 2013
    5
    Odly enough, every works fine when that machine is NOT connected directly to our network and is then registering to the 3CX server via the 3CX Tunnel.
    However, when it is on the same internal network, I always first get the message " 3CX Phone for Windows could not establish a connection to the 3CX Phone System Web API....", and then the registration fails...
    Anyone could give me any pointers? What is this "3CX Phone System Web API" and how does it work?
    Thanks in advance...
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    you can ping the server internally from this machine... VLAN... routing?
  4. leejor
    11,277
    360
    If it is connecting when used outside the local LAN, then it is set to contact the Public IP (or URL), or is set to use the Tunnel. On the LAN it should be set to contact the server by it's local IP. Was the PC running the 3CX phone, on the local LAN when provisioned (I'm assuming that a provisioning email was sent). Is this the only Win 10 having issues?
  5. gdurot
    Sep 25, 2013
    5
    Yes, I can ping the 3CX server properly when connected to the local LAN, so this is not an IP connectivity issue. VLAN is not being used and there is no need for elaborate routing.
    When it is connecting from outside the LAN, the Tunnel is used.
    I tried un-installing/reinstalling the client multiple times, trying the v12 client and the v14 client (no difference), and these installations were done on the local LAN, so provisionning was done with the client connected to the LAN.
    There is no other Windows 10 client on our network...
    Any pointer as to what the "3CX Phone System Web API" is and how it communicates between the 3CX server and the clients? I couldn't find any documentation about this...
    Thanks,
  6. shanus6
    Apr 16, 2015
    17
    I am having the same issues as you gdurot.
    I get the API message on all of my machines after upgrading to V14.
    I too have tried various different settings and uninstall/reinstallation.
  7. 3cxtester
    Jun 10, 2011
    9
    Has anyone solved this issue yet? We have the exact same problem. It was working everything fine with the older 12.0 Phone System.
    The only Windows Phone client that works for us is an old version "12.0.32127.322".
    The Windows Client 12.5 doesn't work independently from the connection type. Tunnel, In office, Out of Office.
    In all cases the firewall for us is disabled, for testing purposes so there is absolutely no interference at all.
      File size:
      17.9 KB
      5,581
  8. DMCinc
    Mar 26, 2015
    I can also confirm this is happening to my Windows users (Windows 8.1) after upgrading from 12.5 to 14.
    Can anyone else confirm that their IIS site for 3CX is now entitled "Instance01" and their are 2 data folders in the C:\ProgramData\3CX folders?
    Hope a fix comes out too, this will delay my future upgrades. :|
  9. datamerge
    datamerge New Member
    Nov 19, 2014
    194
    28
    I am runnning v14 on my Windows 10 computer no problems. Could it be a permissions problem? Have you tried running the app as administrator? Are you a local admin of your own PC?
    Windows is getting very picky about where users can write files now and we see all sorts of strange errors on Windows 8.1 and 10 that are down to where files are being written by the apps.
  10. 3cxtester
    Jun 10, 2011
    9
    I can confirm that this is not a permissions issue. I have tried all compatibility options for the .exe and I have also tried running it as Administrator. It simply does not connect at all.
    Someone from 3CX can help us sort this out?
  11. oOBATOoData
    Nov 12, 2015
    A wizard pointed me to the fact that the softphone has to be set to 3cx for it to work.
    I personaly got it to work as I was able to get a dial tone and voice mail working.
    All under win10Pro Networked but not domained-network HIH
    Data
  12. MichaelB
    MichaelB 3CX Team
    3CX Support
    Aug 25, 2009
    415
    18
    Could someone post a log of the client showing this case?
    Log is here C:\Users\micha\AppData\Roaming\3CXPhone for Windows\Logs
  13. p.pasquino
    Dec 10, 2015
    Same problem also for us, up to version 12.5 there is no problem, when update to 14 (both SP1 SP2) there is an error "Phone System Web API". The computers on which is installed the 3cx client have various operating system :
    - win 7
    - win 8
    - win 10
    But the error message is the same, furthermore it is impossible display address book , presence , call history , chat.
    In some cases it is not possible to operate in CTI ( Yeastar T21 , T23 , T28 that worked correctly before the upgrade )
    In mode 3cx I can make and receive phone calls but it is impossible display address book , presence , call history , chat.
    The windows firewall is off on all machines and i can ping the 3cx server correctly .
    The log file is clean , no error reported.
  14. andreaschr
    Oct 26, 2015
    91
    6
    Hi p.pasquino
    Reprovision your 3CXPhone from management console or send a new welcome email .
    Also confirm that the 3CXPhone is updated .
  15. p.pasquino
    Dec 10, 2015
    We have solved.
    We have not touched anything in 3CX configuration server , the strange thing is that it was not properly resolved FQDN external IP, we have included a simple rule in the firewall ( in the DNS rules ) to enable correct routing and immediately everything is back to work properly.
    Thanks for support
    Have a good day.
    Paolo
  16. SamuelKrawetz
    Jan 13, 2016
    17
    What was the rule that needed to be set up?
