Cannot registered my Iphone from external
Discussion in 'iOS' started by it102, Jan 28, 2012.
  1. it102
    Jan 18, 2012
    Device Info
    Phone Model: Ipad
    Generation: 2 wifi Only
    Firmware Version: 5.0
    Jailbreak: NO
    Cydia Installed: NO
    Issue Info
    Handset: [Phone|Heatphone with MIC|BT]
    Contacts: wifi
    Connection: WiFi
    Server: External
    I cannot use iphone from out side my network
    with 3cx soft phone in my laptop its work fine from any were, but when trying to use iphone
    its not working
    can you please help me
    The configuration that i made in my iphone in attachment
    thanks
      File size:
      24.4 KB
      2,721
      File size:
      26.3 KB
      2,721
      File size:
      26.8 KB
      2,721
      File size:
      26.8 KB
      2,721
      File size:
      35.7 KB
      2,714
    10,853
    299
    Firstly, hide your public IP, to show it is just asking for trouble.
    Are you using the same extension number as the working lap top phone is?
    If not, did you remember to allow Ext 1001 to register remotely?
    Are you trying this from behind the same (remote) router as the laptop?
    There is no "Local SIP port" showing, why?
    Do you see an attempted registration in the 3CX log?
    Does it work when you are on the same LAN "In the office"?
  3. it102
    Jan 18, 2012
    best regards
  4. leejor
    10,853
    299
    This is the port number that you wish 3CX to contact your phone on. Since you are using this at remote locations it is probably best to use something with less chance of a conflict, like 5064, or a bit higher. Port 5090 is usually just used to contact the 3CX PBX when using the tunnel feature, which I don't believe is yet implemented on the iphone. Even if that is missing there should still be something showing in the 3CX PBX log.
    I'm also wondering if the public IP of your 3CX server location needs to go into the Proxy setting (in the first screen).
    Never mind, i just checked my Android phone and that is left blank.
    If you are not seeing any registration attempt, then the registration requests are going to the wrong place, or not going out at all. Since your laptop works, I have to assume that your router/firewall configuration , at the PBX end is correct.
