Cannot start service 3CXCallHistoryService on computer
Discussion in '3CX Phone System - General' started by johnmichael, Apr 14, 2010.
  1. johnmichael
    Apr 6, 2010
    48
    Hi Guys,
    I need help on Call History service. This morning, i wanted to generate a report on Call Log but noticed that the report is empty. When i check the Services Status, "3CX PhoneSystem Call History" service is not running, when i try to Start the service it gives me an error:
    An exception occurred RestartServices Error: Cannot start service 3CXCallHistoryService on computer '.'.
    System Spec:
    Windows Server 2008
    3CX Phone System v8.0.10824.716
    Any help is appreciated. TIA
    Regards,
    John
  2. johnmichael
    Apr 6, 2010
    48
    To Continue my post...
    Why am i getting several logs such as below:
    12:59:48.631|Inf(03)| File not found
    13:00:48.645|Inf(03)| Running Call History Updater iteration
    13:00:48.645|Inf(03)| SELECT value,kind FROM dnallocation
    13:00:48.660|Inf(03)| File not found
    13:01:48.673|Inf(03)| Running Call History Updater iteration
    13:01:48.673|Inf(03)| SELECT value,kind FROM dnallocation
    13:01:48.689|Inf(03)| File not found
    13:02:48.702|Inf(03)| Running Call History Updater iteration
    13:02:48.702|Inf(03)| SELECT value,kind FROM dnallocation
    13:02:48.718|Inf(03)| File not found
    13:03:48.731|Inf(03)| Running Call History Updater iteration
    13:03:48.731|Inf(03)| SELECT value,kind FROM dnallocation
    13:03:48.747|Inf(03)| File not found
    13:04:48.760|Inf(03)| Running Call History Updater iteration
    13:04:48.760|Inf(03)| SELECT value,kind FROM dnallocation
    13:04:48.775|Inf(03)| File not found
    13:05:48.789|Inf(03)| Running Call History Updater iteration
    13:05:48.789|Inf(03)| SELECT value,kind FROM dnallocation
    13:05:48.804|Inf(03)| File not found
    13:06:08.975|Inf(03)| 3CX Call History Service process exiting.
    On our CallHistoryService.log. Are configuring something wrongly?
    Can anyone please advice on my problem. Thanks in advance.
    Regards,
    John
  3. johnmichael
    Apr 6, 2010
    48
    Any possible solution guys?
    Just for the info we have a license and we are not using a free version, and i hope engineers/support from 3CX could somehow help. We just recently use 3CX and i already like the system but since it doesn't come with a reporting system that we want, i was task to develop our own. Unfortunately, It's really quite frustrating that i cannot up the 3CXCallHistoryService.
    I hope someone could help me fix this issue.
    Thanks in advanced.
  4. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Hi John, check event viewer if there are any errors due to call history service.
    Also go to settings > advance and select verbose logging level.
    Restart all services. And when you replicate the call history issue generate a support info and send me the log file.
    Also check if your system has latest updates installed.
  5. johnmichael
    Apr 6, 2010
    48
    Hi MichaelB,
    Thanks for the reply, i already send you the log files.
    Thanks a lot.
    John
  6. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Hi John,
    so install latest .net and ensure yourself that your machine is fully update with the latest updates,
    and let me know.
    Thanks in advance
  7. johnmichael
    Apr 6, 2010
    48
    Updating the Server fixed all the problems.
    Thank a lot MichaelB.
