Cannot transfer using Polycom phones?
Discussion in '3CX Phone System - General' started by Denny, Jul 6, 2007.
  1. Denny
    Dec 22, 2006
    15
    I have tried using Polycom IP 501 SIP and 330 SIP phones to transfer when I receive calls. I can call the extensions but I can't transfer.
    Here are the log:
    17:46:22.078 StratLink::eek:nHangUp [CM104001] Call(125): Ln:10000@Viatalk hung up call; cause: BYE; from IP:216.218.201.134
    17:46:18.500 CallConf::eek:nIncoming [CM003002] Call(126): Destination not available for call from sip:104@192.168.200.15 to sip:10@192.168.200.15
    17:46:18.500 CallConf::Rejected [CM103005] Call(126) is rejected: Destination does not exist, or is not registered
    17:46:18.484 CallConf::eek:nIncoming [CM103002] Call(126): Incoming call from 104 (Ext.104) to sip:10@192.168.200.15
    17:46:11.125 MediaServerReporting::RTPSender [MS004000] Call(125) Ext.104: (ACTIVE): Can't send RTP stream to 0.0.0.0:2228 destination unreachable
    17:46:07.687 CallLegImpl::eek:nConnected [CM103001] Call(125): Created audio channel for Ext.104 (192.168.200.113:2228) with Media Server (192.168.200.15:7330)
    17:46:07.671 StratInOut::eek:nConnected [CM104005] Call(125): Setup completed for call from Ln:10000@Viatalk to Ext.104
    17:46:07.656 CallLegImpl::eek:nConnected [CM103001] Call(125): Created audio channel for Ln:10000@Viatalk (216.218.201.134:17500) with Media Server (75.22.169.234:9000)
    17:46:03.515 CallConf::eek:nProvisional [CM103003] Call(125): Ext.104 is ringing
    17:46:03.203 CallConf::eek:nIncoming [CM103002] Call(125): Incoming call from 16198088696 (Ln:10000@Viatalk) to sip:16195797351@sanfrancisco-1.vtnoc.net:5060
    Our extensions are from 100-110. You can see Phone was picked up on 104 and tried transfering to 103. I see the error 17:46:18.484 CallConf::eek:nIncoming [CM103002] Call(126): Incoming call from 104 (Ext.104) to sip:10@192.168.200.15. Why is it going to sip:10@192.168.200.15?
    Any ideas?
  2. Denny
    Dec 22, 2006
    15
    3CX Phone System Version3.0.2295.0
  3. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    try playing with the settings : supports reinvite and Support "Replace headers".
    Might solve the transfer issue.
  4. Denny
    Dec 22, 2006
    15
    Under the VOIP Gateway, I enabled the "Specify how this voip provider handles transfers.
    Supports Re-Invite
    Supports 'Replaces' header
    Logs:
    19:23:30.328 StratLink::eek:nHangUp [CM104001] Call(12): Ln:10000@Viatalk hung up call; cause: BYE; from IP:216.218.201.134
    19:23:24.671 MediaServerReporting::RTPSender [MS104000] Call(12) Ext.105: (ACTIVE) RTP stream to 192.168.200.112:2222 restored.
    19:23:19.796 CallConf::eek:nIncoming [CM003002] Call(14): Destination not available for call from sip:105@192.168.200.15 to sip:10@192.168.200.15
    19:23:19.796 CallConf::Rejected [CM103005] Call(14) is rejected: Destination does not exist, or is not registered
    19:23:19.781 CallConf::eek:nIncoming [CM103002] Call(14): Incoming call from 105 (Ext.105) to sip:10@192.168.200.15
    19:23:17.640 MediaServerReporting::RTPSender [MS004000] Call(12) Ext.105: (ACTIVE): Can't send RTP stream to 0.0.0.0:2222 destination unreachable
    19:23:12.156 CallLegImpl::eek:nConnected [CM103001] Call(12): Created audio channel for Ext.105 (192.168.200.112:2222) with Media Server (192.168.200.15:7036)
    19:23:12.156 StratInOut::eek:nConnected [CM104005] Call(12): Setup completed for call from Ln:10000@Viatalk to Ext.105
    19:23:12.140 CallLegImpl::eek:nConnected [CM103001] Call(12): Created audio channel for Ln:10000@Viatalk (216.218.201.134:13720) with Media Server (192.168.200.15:9002)
    This doesn't effect incoming calls. It also effects internal extension transfers. What i mean is if I connect from one extention to another and try to transfer that call to another it also doesn't work.
  5. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    try setting it in your extensions properties
  6. Denny
    Dec 22, 2006
    15
    It is enabled. I have tried it disabled also. Didn't work. For some reason when i put call on to transfer, when i try to input the extension, it dies after 2 digits. It beeps out after 2 digits and I can't finish. If I put call on hold, then hit new call it will allow me to call another extension but I can't conference at all.
  7. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    btw just for the record, you tryed disabling the supports reinvite in the providor settings too? else try it.
  8. Denny
    Dec 22, 2006
    15
    I have it all disabled.
    19:46:11.585 StratLink::eek:nHangUp [CM104001] Call(21): Ln:10000@Viatalk hung up call; cause: BYE; from IP:216.218.201.134
    19:46:04.866 CallConf::eek:nIncoming [CM003002] Call(22): Destination not available for call from sip:105@192.168.200.15 to sip:10@192.168.200.15
    19:46:04.866 CallConf::Rejected [CM103005] Call(22) is rejected: Destination does not exist, or is not registered
    19:46:04.835 CallConf::eek:nIncoming [CM103002] Call(22): Incoming call from 105 (Ext.105) to sip:10@192.168.200.15
    19:46:03.163 MediaServerReporting::RTPSender [MS004000] Call(21) Ext.105: (ACTIVE): Can't send RTP stream to 0.0.0.0:2222 destination unreachable
    19:45:55.163 CallLegImpl::eek:nConnected [CM103001] Call(21): Created audio channel for Ext.105 (192.168.200.112:2222) with Media Server (192.168.200.15:7058)
    19:45:55.163 StratInOut::eek:nConnected [CM104005] Call(21): Setup completed for call from Ln:10000@Viatalk to Ext.105
    19:45:55.147 CallLegImpl::eek:nConnected [CM103001] Call(21): Created audio channel for Ln:10000@Viatalk (216.218.201.134:10800) with Media Server (192.168.200.15:9000)
    19:45:49.116 CallConf::eek:nProvisional [CM103003] Call(21): Ext.103 is ringing
    19:45:48.835 CallConf::eek:nIncoming [CM103002] Call(21): Incoming call from 16198088696 (Ln:10000@Viatalk) to sip:16194442200@75.22.169.234:5060
    It is still accepting 2 digits? it beeps out when i try to put in third digit.
  9. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    try to disable any local firewall running on the 3cxmachine or machine that runs any softphone.
  10. Denny
    Dec 22, 2006
    15
    No firewall running.
  11. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    so somehow you can only type two digits, hence the 10 in the sip logs..
    Not sure why that is, maybe some1 can pick up on this one?
  12. Denny
    Dec 22, 2006
    15
    yes. our extensions are from 100-110. I pick up call, transfer, put in any extension it beeps out right after i put in 10
  13. Denny
    Dec 22, 2006
    15
    Found the fix.
    Fix is on the Polycom phone itself.
    Under SIP
    Local Settings
    Made sure Digitmap is cleared.
    Thanks!
  14. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    cool :D glad you solved it.
