Cannot use dial pad while in call
Discussion in '3CX Phone System - General' started by OpacityZero, Aug 19, 2014.
  1. OpacityZero
    Aug 19, 2014
    We recently did some windows updates on the 3CX server and rebooted it. Since then we cannot use the dial pad while in calls. It was working fine before the reboot. Any ideas?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    What OS are you running?
    Are you 100% up-to-date on windows updates ? and running .NET 4.5 + hotfixes ?
    Is this a 3CX Phone System v12 SP6 ?
  3. leejor
    10,861
    302
    Is this referring to he use of DTMF on outside calls?
    What type (make/model) of sets are you using? Are they all behaving the same, or just some?
    What type of trunks do you use, Gateway, VoIP, etc. ?
