Can't access Managment console via browser
Discussion in '3CX Phone System - General' started by open7, Aug 30, 2010.
  1. open7
    Jan 7, 2010
    30
    I am on my local network trying to access the server managment console via Firefox or IE at http://192.168.1.xx:5481/MainForm.wgx and I get the error after I log in with my username and password:
    "An exception occurred MainForm Error: Index was outside the bounds of the array."
    When I click OK the form is blank.
    This same thing happens if I try to use Firefox or IE from the server itself.
    This is obviously not related to the Browser (I tried both IE and Firefox) and it happens from multiple computers.
    Any ideas?
    11,283
    360
    Have you tried after restarting 3CX or re-booting the PC?
  3. open7
    Jan 7, 2010
    30
    Indeed, this fixes it. But this has happened several times and I have had to reboot the server for it to work again. Any idea what could be causing it?
