can't access MySQL database(VAD)
Discussion in 'CRM / Helpdesk / App Integration' started by pondsenth, Nov 4, 2016.
  1. pondsenth
    Nov 4, 2016
    8
    apldoor likes this.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,611
    126
    That's the way to go with the VAD and a database. Did you check the logs to see what's the problem? Please take a look at this article to understand what logs you should check:
    http://www.3cx.com/blog/docs/troublesho ... lications/
    When using MySQL, a common error is installing a 32 bits ODBC driver. Please note that the VAD app runs as a 64 bits app, so you need to install a 64 bits ODBC driver, and configure your DSN in the 64 bits ODBC applet.
    Kind regards.
    apldoor likes this.
