Can't add outbound rule BUG
Discussion in '3CX Phone System - General' started by AldoLinares, Jan 12, 2008.
  1. AldoLinares
    AldoLinares New Member
    Nov 12, 2007
    135
    If i add a rule with this settings:
    Prefix: 71044
    Route: PSTN
    Strip Digits: 2
    Prepend: XXXXXXXXXX (10 digit)
    it goes out trough the PSTN but i got a message from the PSTN Provider that i dial the number wrong, i know its ok because if a dial with prefix 9 that have only strip 1 digit it works, and in verbouse log i cant see what number is trying to call
    I need this to add codes for dialing special numbers from extension that are not going to be able to make outbound calls only this special numbers
    this is the log:
    20:38:43.906 Call::Terminate [CM503008]: Call(24): Call is terminated
    20:38:38.859 CallLeg::eek:nConfirmed Session 171 of leg C:24.1 is confirmed
    20:38:38.718 CallCtrl::eek:nLegConnected [CM503007]: Call(24): Device joined: sip:10000@192.168.1.91:5060
    20:38:38.703 CallCtrl::eek:nLegConnected [CM503007]: Call(24): Device joined: sip:100@192.168.1.116:5060;transport=udp
    20:38:38.703 MediaServerReporting::SetRemoteParty [MS210003] C:24.1:Answer provided. Connection(transcoding mode):192.168.1.90:7074(7075)
    20:38:38.703 MediaServerReporting::SetRemoteParty [MS210001] C:24.2:Answer received. RTP connection: 192.168.1.91:5016(5017)
    20:38:38.703 CallLeg::setRemoteSdp Remote SDP is set for legC:24.2
    20:38:38.703 Line::printEndpointInfo [CM505002]: Gateway:[Telnor] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 0001, Ch:7) 1.0.1.2] Transport: [sip:192.168.1.90:5060]
    20:38:38.703 CallCtrl::eek:nAnsweredCall [CM503002]: Call(24): Alerting sip:10000@192.168.1.91:5060
    20:38:35.171 MediaServerReporting::SetRemoteParty [MS210002] C:24.2:Offer provided. Connection(transcoding mode): 192.168.1.90:7076(7077)
    20:38:35.156 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(24): Calling: PSTNline:10000@[Dev:sip:10000@192.168.1.91:5060, Dev:sip:10002@192.168.1.91:5062]
    20:38:35.125 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:71044@192.168.1.90]
    20:38:35.125 MediaServerReporting::SetRemoteParty [MS210000] C:24.1:Offer received. RTP connection: 192.168.1.116:5004(5005)
    20:38:35.125 CallLeg::setRemoteSdp Remote SDP is set for legC:24.1
    20:38:35.125 Extension::printEndpointInfo [CM505001]: Ext.100: Device info: Device Identified: [Man: GrandStream;Mod: GXP-2000;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.1.4.18] Transport: [sip:192.168.1.90:5060]
    20:38:35.093 CallCtrl::eek:nIncomingCall [CM503001]: Call(24): Incoming call from Ext.100 to [sip:71044@192.168.1.90]
    20:38:35.093 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:71044@192.168.1.90 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.116:5060;branch=z9hG4bK0d654f517ada6464
    Max-Forwards: 70
    Contact: [sip:100@192.168.1.116:5060;transport=udp]
    To: [sip:71044@192.168.1.90]
    From: "Alma Recepcion"[sip:100@192.168.1.90];tag=8ac7397770676477
    Call-ID: bc34620df00d3244@192.168.1.116
    CSeq: 22141 INVITE
    Allow: INVITE, ACK, CANCEL, BYE, NOTIFY, REFER, OPTIONS, INFO, SUBSCRIBE, UPDATE, PRACK, MESSAGE
    Proxy-Authorization: Digest username="100",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:71044@192.168.1.90",nonce="12844586314:9c0bb13ee50471f5f604d9efeaf76a31",response="5e5fd2977c1e69efb012e8acb7d8ee59"
    Supported: replaces, timer, path
    User-Agent: Grandstream GXP2000 1.1.4.18
    Content-Length: 0
