Can't Answer Calls
Discussion in '3CX Phone System - General' started by darryla, Oct 25, 2007.
  1. darryla
    Oct 11, 2007
    30
    I'm not sure if this is the phone or the PBX, but I can't seem to get this to work:
    Phone 1: Dial extension 101 (other phone)
    Phone 2: Ring Ring
    Me: Pick up handset of Phone 2
    Nothing happens! The call won't connect. On the phone's screen it says "Answer or Reject". So I push "answer" -- nothing! I push the button next to the extension -- nothing!
    Me: I push reject and the call goes away
    ...5 seconds later...
    Phone 2: ring ring
    (What the? I thought I said reject!)
    Me: I push reject on Phone 2
    Phone 2: ring ring
    Me: I hang up Phone 1
    Phone 2: ring ring
    (What the? I hung up already!)
    Clearly there is something awry. All extensions are "external" and the media check box is on.
  2. darryla
    Oct 11, 2007
    30
    There's more...
    I have a softphone -- when I call Phone 1 or Phone 2 with the softphone, the same thing happens.
    When I use the softphone or Phone 1 or Phone 2 to call a land line, it works.
  3. darryla
    Oct 11, 2007
    30
    My phones are Polycom 650's
  4. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Can you setup two softphones and try softphone to softphone? Would eliminate or establish if hardware very quickly.
