Can't answer random calls after upgrade to 15.5 SP2 and Yealink 66.82.0.20
Discussion in '3CX Phone System - General' started by Jes.amos, Nov 23, 2017.
  1. Jes.amos
    Nov 1, 2017
    22
    Since we installed the update to the system and upgraded the firmware on the phones last Friday we are getting calls with either %22 or a " in front of the CLID on random calls. When this happens the call is unanswerable from either a soft phone in CTI mode or a yealink desk phone.
    11/23/2017 9:33:27 AM %22HARKER (******2444) IVR (809) 00:00:10
    On the deskphone the CLID was displayed as "HARKER (******2444) and in the call log it is displayed with the %22 replacing the ".
    From Deskphone 107 we attempted to answer the call by pressing the answer button on the deskphone, by hitting the answer button in the soft phone in CTI mode, and by dragging the call to the extension from the reception view. The call had to be rejected in order to answer other calls in the queue.
    In the activity log there was no mention of Ext 107 attempting to pickup the call
    Anyone have any ideas?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,358
    535
    Hello @Jes.amos
    Your issue does not look like its related to the update. There is nothing in the update that would cause calls with weird call id's arriving to the PBX. Having said that do these call follow any inbound rules or do they hit the extension directly? Can you tell is the calls are arriving from the provider? Also are your phones provisioned as local or remote? Does this happen often?
    As a first step you should step the logging level to verbose so can get more details regarding the issue. You can set this up by navigating to Dashboard / Activity Log / Options and set it to verbose. Restart all services so that this applies. Once the issue re-occurs check your activity log for more details.
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    It is most likely a hacker exploiting the open ports and doing direct SIP.
    You can protect yourself at the router level (assuming you are behind same) by implementing rules at the firewall to only allow the desired IP(s) and drop the others. Additionally, the phones will have a setting that you can use to tell the phone to only accept calls from the SIP server(s) associated to the account(s) - "Accept SIP Trust Server Only".
    I suppose it possible that somehow, during the firmware upgrade this setting got changed or if a new template came out it too may be affected. To find out, manually enable the setting and then re-provision the phone. If the setting changed, then you may need to edit the template to re-enable. If not, then perhaps it was the firmware. In any event, check the template to insure the setting is enabled. You could then re-provision all phones so that any missing the setting will now activate same.
  4. Jes.amos
    Nov 1, 2017
    22
    Logging is already set to verbose, we have been unable to reproduce the on demand, the issue only seems to only present when it is another medical clinic calling. The clinic may be in the 3CX phonebook though so I'll check to see if there are any special characters in the phonebook entry.
  5. Jes.amos
    Nov 1, 2017
    22
    It isn't that there are unwanted calls coming in, it is that important wanted calls coming over the SIP trunk are rendered unanswerable and have a weird CLID signature.
