Cant Call Out
Discussion in '3CX Phone System - General' started by uk26, Mar 25, 2009.
  1. uk26
    Mar 25, 2009
    12
    Hi, i cant seem to dial out
    Any ideas
    I get the message on the phone (Destination not found)
    error logs
    19:21:26.046 [CM503008]: Call(32): Call is terminated
    19:21:26.041 [CM503015]: Call(32): Attempt to reach <sip:0800800150@192.168.0.1:5060> failed. Reason: Not Found
    19:21:26.040 [CM503003]: Call(32): Call to sip:800800150@voiptalk.org:5060 has failed; Cause: 404 Not Found; warning: Noisy feedback tells: pid=10759 req_src_ip=77.240.48.201 req_src_port=5060 in_uri=sip:800800150@voiptalk.org:5060 out_uri=sip:800800150@voiptalk.org:5060 via_cnt==2; from IP:77.240.48.201:5060
    19:21:22.524 [CM503004]: Call(32): Calling: VoIPline:800800150@(Ln.10001@VOIP TALK)@[Dev:sip:844233155@voiptalk.org:5060]
    19:21:22.418 [CM503010]: Making route(s) to <sip:0800800150@192.168.0.1:5060>
  2. Cjay
    Cjay New Member
    Feb 24, 2007
    199
    By the looks of things you are dialing a UK 0800xxx number, but what is actually being sent to Voiptalk is 800xxx - which Voiptalk rejects. Do you have an outbound rule set up that is inadvertently stripping off the leading 0? [and a supplementary question - does Voiptalk accept 0800 calls? on my system I route these over my BT line via a SPA3102 gateway]
    Chris
  3. uk26
    Mar 25, 2009
    12
    Hi, Right i have updated the settings as you suggested and that work. :) thanks for the tip
    now, when i make an outgoing call, i get the ringing tone for like 5 seconds before it actually connects the call
    makes you think when you hear the ringing that it is actually ringing the dialed number, but its not the case there is a delay
    any ideas?
  4. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    Unfortunately as far as i know you are gonna have to live with the Delay :p
  5. uk26
    Mar 25, 2009
    12
    Why is there a delay in the system? why does it play a ringing tone when the call has yet to be passed to the Sip provider?
  6. LeonidasG
    Nov 19, 2008
    1,557
    118
    I'm just making a guess here.
    I cant answer myself why there is a delay in your system, it can be anything, but the part where you can hear a ringing tone when you make a call is considered normal.
    Let me answer your question with another question :p
    Would you prefer not to hear a Ringing tone when you make a call? It's just an indication that a call is in progress.
    Even if the temporary Ringing tone was removed i sincerely cant see how it would be a change towards the best.
    That's just my opinion nothing more...
    if you disagree with me you can just post it as a Feature Suggestion on the appropriate forum, you should get some decent feedback there.
  7. uk26
    Mar 25, 2009
    12
    i was more concerned why there is a delay in connecting calls between 5-8 seconds then it will connect the call to the voip provider.
    if i connect the phones direct to the provider it connects right away
  8. uk26
    Mar 25, 2009
    12
    also i appear to get a double rinning tone
    1 for the 3CX System and one for the call its self and you can hear them both over lapping
  9. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,970
    273
    First of all i suggest using a support VoIP Provider first such as SIPgate and see if the problem persists.
    Secondly, check that you are using the STUN servers recommended by your VOIP provider. (see manual how to configure this)
