Can't call to a outside number (with voipbuster)
Discussion in '3CX Phone System - General' started by VJSmurf, Sep 20, 2007.
  1. VJSmurf
    Sep 20, 2007
    5
    Finaly i've got 3CX working. Internal numbers works OK. I've got also a VOIP line registered. (voipbuster) But, i cant make a call to a outside number (like 003134125****) :( What's happening or what am I doing wrong? :roll:
    Greetz and thanks fot help
  2. touficjohn
    Sep 5, 2007
    20
    Under "Line Status" is the status indicator for VoipBuster green?
    Did you bind the extension to the media server?
    Could you post a log of what happens when you try and make a call?
  3. VJSmurf
    Sep 20, 2007
    5
    Jup, it's green. (Line status --> Voip Lines)
    Uhm, I think that i've bind it, but i'm not sure.....
    If I try to make a outside call (use SJPhone) is he ringing, but after 5 ring's he show's 'Not found'
    If I try it with a Grandstream GXP2000 (wich we also use) is he also ringing and after 5 ring's is he telling me '404 Not Found Wrong number or remote party not online'
    :roll:
  4. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Post logs please. Its the best way to get a proper response. Otherwise its shooting in the dark, too many possibilities. I use VoIPBuster with no issues.
  5. VJSmurf
    Sep 20, 2007
    5
    Oke, here the logs.
    08:57:24.093 CallConf::Rejected [CM103005] Call(24) is rejected: User not found
    08:57:24.093 StratInOut::eek:nCancel [CM104008] Call(24): Call from Ext.300 to 03134125**** terminated; cause: 404 User not found; from IP:194.120.0.198
    08:57:07.796 CallConf::eek:nProvisional [CM103003] Call(24): Ln:10000@Voipbuster.com is ringing
    08:57:07.015 CallConf::eek:nIncoming [CM103002] Call(24): Incoming call from 300 (Ext.300) to sip:003134125****@192.168.1.110:5060
    08:53:01.031 ClientRegs::eek:nSuccess [CM113005] Registration of sip:VJSmurf@sip.voipbuster.com is successful
    08:53:00.718 ExtLine::Register [CM110004] Send registration for "VJSmurf"<sip:VJSmurf@sip.voipbuster.com>
    08:53:00.718 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10000' device='Voipbuster.com'
    08:53:00.718 ClientRegs::eek:nSuccess [CM113005] Registration of sip:VJSmurf@sip.voipbuster.com is successful
    08:53:00.671 StunClient::process [CM115002] STUN resolved external IP=81.207.57.212:63689 by server 64.69.76.23
    08:53:00.484 ExtLine::Register [CM110004] Send registration for "VJSmurf"<sip:VJSmurf@sip.voipbuster.com>
    08:53:00.484 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10000' device='Voipbuster.com'
    08:53:00.468 StunClient::process [CM115002] STUN resolved external IP=81.207.57.212:63689 by server 64.69.76.23
    08:33:00.468 ClientRegs::eek:nSuccess [CM113005] Registration of sip:VJSmurf@sip.voipbuster.com is successful
    I hope that you can tell me what I'm doingwrong..... :roll:
  6. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Where are you located? Are you using right country code? VoIPBuster needs format 00+country code+number. From your logs
    It seems that the outbound rule is stripping a "0" off.. Check rule "transform mask" for an "r".
  7. VJSmurf
    Sep 20, 2007
    5
    My location is the Netherlands. Country code is 0031 (wich I use when I'm calling) Monday I will check the rull. (I'm already at home) I try than again and let the result know here.
  8. VJSmurf
    Sep 20, 2007
    5
    Thanks, I can call to an outside number. (put an extra 0 for the number) Only, if I call and the other side takes the phone, I can't hear anything...
    Here the log.
    10:44:22.593 StratLink::eek:nHangUp [CM104001] Call(9): Ln:10000@Voipbuster.com hung up call; cause: BYE; from IP:194.221.62.198
    10:44:08.453 CallLegImpl::eek:nConnected [CM103001] Call(9): Created audio channel for Ln:10000@Voipbuster.com (194.221.62.189:57694) with Media Server (192.168.1.110:9016)
    10:44:08.437 StratInOut::eek:nConnected [CM104005] Call(9): Setup completed for call from Ext.300 to Ln:10000@Voipbuster.com
    10:44:08.437 CallLegImpl::eek:nConnected [CM103001] Call(9): Created audio channel for Ext.300 (192.168.1.101:5004) with Media Server (192.168.1.110:7016)
    10:44:03.171 CallConf::eek:nProvisional [CM103003] Call(9): Ln:10000@Voipbuster.com is ringing
  9. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Log sequence looks OK. Throughout the forum the majority of audio issues were due to port forwarding setup. Give http://www.3cx.com/forums/categorie...is-gets-a-sticky-1697/?highlight=ports+sticky a read and make sure you have it all covered. Also, for me personally, I prefer not to select "Bind to Media Server" or "PBX delivers audio" since I find more issues on audio quality when the PBX / PC becomes another middleman for audio. Now this could just be because my PC is at the very lower end of the minimum specs :) but I have no audio issues, and have those options unchecked.
