Can't change Font Size in Panel
Discussion in '3CX Phone System - General' started by wannaorn, Jul 29, 2012.
  1. wannaorn
    Jul 29, 2012
    How do I change font size in panel. The font size is too tiny especially Thai Language.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    As far as I know, there is no functionality that allows for font size changing within the applications. You will need to look at the display settings, accessibility settings or personalize settings within your particular version of the Windows OS and adjust these to make it more readable.
  3. palmaz
    Aug 22, 2017
    43
    20
    We have many staff who find the font too small to read. Need to be able to change the font size, without enabling windows "large fonts".
  4. agp
    agp 3CX Team
    Aug 19, 2015
    151
    22
    Hi @palmaz ,
    You can always use this quick and easy way to change the font size :)
