Can't change receptionist prompt
Discussion in '3CX Phone System - General' started by JVH, Apr 26, 2010.
  1. JVH
    JVH
    Apr 25, 2007
    18
    This is strange.
    I had originally created a voicemail prompt StrVoicemail.wav and selected it in the menu.
    This worked fine.
    An employee left and I needed to remove him from the menu.
    I recorded a new copy of StrVoicemail.wav.
    I selected it in the menu I applied it and then played it. It plays correctly
    I dial in and it plays the old prompt.
    I tried this several times.
    I did a search on StrVoicemail on the sytem and deleted all other copies found.
    I went into the menu and selected a completely different prompt StrLocation.wav, applied, played ok.
    Dialed in and it played the StrLocation prompt.
    I went back to the menu and replaced the prompt with the StrVoicemail, applied, played ok.
    Dialed in and I get the old (Wrong) Strvoicemail prompt again.
    Insert "Twilight Zone Music"
    Where could it be getting the old wave file from?
    3CXPhoneSystem 8.0.10708.0
    11,277
    360
    Very odd, especially if you've done a search and delete on the system. Have you tried a reboot of the PC? A search for all (*.wav) files, just to see what else comes up?
  3. t4mack
    Jan 19, 2010
    56
    The Irv is located in c:\documents and setting\all users\application data\3cx\data\IRV. this is in windows xp and windows 2003. i don't know what version of windows your running this on. But check ther if you haven't already. Place your Irv there and then try calling.
  4. JVH
    JVH
    Apr 25, 2007
    18
    I actually did put all the prompt wave files in that directory once I located it.
    But it was still acting like it had a cache somewhere.
    However rebooting the sytem corrected the issue.
    I wonder if it was in the internet explorer temp files under a coded name. Since the interface is web based.
    John
