Solved Can't conference two callers from Yealink T48G
Discussion in '3CX Phone System - General' started by seantp, Mar 15, 2018.
  1. seantp
    Sep 9, 2017
    29
    I need the ability to conference in callers from my phone. 2 way calling, not start a conference bridge.
    I have the latest 3CX software and a Yealink T48G
    I place the first call, then I hit the conference button. It places the first call on hold and I proceed to dial the number. When I try to connect I get an error Call Failed and Temporarily unavailable.
    I've done some searching for the error but none of the results I've found seem to apply. I suspect an outbound rule from what I've read, but they've all referred to older versions of 3CX.
    Help!
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    940
    149
    Can you make normal outbound calls using the same number ? , if not then you probably need to setup rules https://www.3cx.com/docs/manual/outbound-rules/
    Do you have PSTN or SIP lines ?. If Sip how many concurrent calls have you configured.
  3. seantp
    Sep 9, 2017
    29
    I have SIP. It was my bad, I had forgotten I reduced the number of channels on my SIP trunk. Looking at elastic trunks to save some money and avoid an unnecessary limit.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,888
    321
    Glad to see the issue has been resolved and thank you sharing your solution
