Can't connect machine to machine, only voicemail
Discussion in '3CX Phone System - General' started by larsenbh, May 9, 2007.
  1. larsenbh
    May 8, 2007
    6
    Hello there,
    I have installed 3CX on a machine with XP Pro SP2. It sets up fine, and I can reach the admin console from any machine on the network. Also, via softphone, the other machines are able to register, and I see them in the status view. However, when I try to call internal extensions, the call does not connect, it just goes to voicemail (per my settings).
    Any ideas?
    Here is the log:
    Code:
    10:26:27.598  	StratInOut::onHangUp  	Call(C:8): Call from Ext.120 to 999 has been terminated
    10:26:27.578 	MediaServerReporting::RTPReceiver 	from 'larsenb-lt:0/MediaServer':EP:0000000E@ Wrong data length 0 for payload 0
    10:26:23.722 	CallLegImpl::onConnected 	Call(C:8): Created audio channel for Ext.120 (10.10.200.15:8000) with Media Server (10.10.200.45:7026)
    10:26:23.432 	  	gt;>:Can't find source interface to use
    10:26:23.362 	CallConf::onIncoming 	Call(C:8): Incoming call from Ext.120 to sip:123@10.10.200.45
    10:26:13.818 	MediaServerReporting::RTPReceiver 	from 'larsenb-lt:0/MediaServer':EP:0000000C@ Wrong data length 0 for payload 0
    10:26:13.808 	StratInOut::onHangUp 	Call(C:7): Call from Ext.123 to 999 has been terminated
    10:26:13.538 	MediaServerReporting::DTMFhandler 	from 'larsenb-lt:0/MediaServer':DTMF (in-band) from 10.10.200.44:8000 detected.
    10:26:10.143 	CallLegImpl::onConnected 	Call(C:7): Created audio channel for Ext.123 (10.10.200.44:8000) with Media Server (10.10.200.45:7022)
    10:26:09.822 	  	gt;>:Can't find source interface to use
    10:26:09.752 	CallConf::onIncoming 	Call(C:7): Incoming call from Ext.123 to sip:120@10.10.200.45
  2. larsenbh
    May 8, 2007
    6
    Also, if it is useful, I'm successful in registering a Norwegian VOIP provider. This provider works fine with regular softphone. When making a call to my U.S. cell phone, it rings, and the cell phone can hear the soft phone, but not vice versa.
    Here is the log for that call:
    Code:
    0:51:17.180  	StratLink::onHangUp  	Call(C:F): Ext.123 hung up call; reason: BYE
    10:51:17.180 	MediaServerReporting::RTPReceiver 	from 'larsenb-lt:0/MediaServer':EP:0000001C@ Wrong data length 0 for payload 0
    10:51:05.223 	CallLegImpl::onConnected 	Call(C:F): Created audio channel for Ln:10000@IP Link (216.168.162.95:26144) with Media Server (216.164.83.193:9002)
    10:51:05.213 	StratInOut::onConnected 	Call(C:F): Setup completed for call from Ext.123 to Ln:10000@IP Link
    10:51:05.213 	CallLegImpl::onConnected 	Call(C:F): Created audio channel for Ext.123 (207.172.31.66:8000) with Media Server (10.10.200.45:7052)
    10:51:02.379 	CallConf::onProvisional 	Call(C:F): got response from 0016173195099
    10:51:02.368 	CallConf::onProvisional 	Call(C:F): got response from 0016173195099
    10:50:55.388 	CallConf::onIncoming 	Call(C:F): Incoming call from Ext.123 to sip:90016173195099@10.10.200.45
    10:50:35.249 	ClientRegs::onSuccess 	Registration of sip:35565905@sipit.iplink.no:5061 is successful
    10:50:34.789 	ExtLine::Register 	Send registration for "35565905"<sip:35565905@sipit.iplink.no:5061>
  3. larsenbh
    May 8, 2007
    6
    Also, I'm using Express Talk as my softphone client. Not sure if that's a problem?
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    10:51:05.213 CallLegImpl::eek:nConnected Call(C:F): Created audio channel for Ext.123 (207.172.31.66:8000) with Media Server (10.10.200.45:7052)
    Extension 123 is configured as local but phone uses global addresses.
    Change phone settings to use local address. (for Express Talk, uncheck all checkboxes under Settings/Network "Allowing Incoming Calls and Audio.....")
    If phone resides outside of local network (where phone system is installed) then setup extension 123 as external.
    Stepan
  5. silentfun
    silentfun Member
    Dec 11, 2006
    364
    i have had this messages to and replaced the phone standard audio codecs from 729 to 711 and this type of message was away.
  6. larsenbh
    May 8, 2007
    6
    Thanks - I will try that. How do I change the codecs, by the way?
  7. larsenbh
    May 8, 2007
    6
    SY: THe problem you're describing seems to be affectin outbound calls, but still doesn't explain why I can't connect computer to computer, right?
    As far as codecs, these are my audio codecs on the server machine:
    [​IMG]
  8. silentfun
    silentfun Member
    Dec 11, 2006
    364
    i did it in my IPPhone (hardware)
    711 ist good quality and good for Dialtone issues but it will also need the most bandwith
    al three parts need the codec (the server bpx and both client
  9. SY
    3CX Support
    Jan 26, 2007
    1,825
    No, my post describes correct configuration of phone that is a local extension.
    It is a real reason of all problems you described. Just setup both phones to use local IP.
    Stepan
