Can't connect to management console after installation
Discussion in '3CX Phone System - General' started by Joseph Cruz, May 28, 2017.
  1. Joseph Cruz
    May 28, 2017
    My installation was successfully but i can't connect to my management console with the url https://myhost.3cx.us:5001.
    I'm using an Airpot Express router. I have Nat port mapping activated. I installed using VMWare VM in Mac. From my mac i can connect to web server in the VM.
    I don't know what i need to check whats happening or what i need to do to connect to the management console. I've used the host name and the ip name.
    #1 Joseph Cruz, May 28, 2017
  2. jbryant84
    jbryant84 New Member
    Apr 6, 2016
    109
    40
    Try it from 4g or an external machine. Try the local ip instead of fqdn. Nat reflection might not be turned on in your router.
  3. Hello @Joseph Cruz
    Send me your FQDN in a private message to test it from our office.
