Can't connect to Server
Discussion in '3CX Phone System - General' started by WWestermann, Nov 16, 2016.
  1. WWestermann
    Nov 16, 2016
    Hi there,
    i installed the Version 15 with the Debian-ISO-File.
    The first connection via Webinterface is ok, no problem. But the second try to connect the Server-Website won't work.
    "Website not found", i can ping the Server and i can connect it via SSH, but not via Web-Interfaces.
    Can anyone help me?
  2. George_3cx
    George_3cx Guest
    Dear WWestermann,
    In order to troubleshoot this issue you have to check multiple aspects of the configuration you did. A few of them can be found below:
    - Make sure that all services of the pbx are running by using the Linux command service 3* status.
    - Are you using the correct FQDN or Ip address and port in your web browser?
    - If you are trying to access it remotely did you allowed the appropriate ports on your firewall/router (port 5001 or 443) ?
    - Also make sure if you are trying to access it from another machine that the network connections are correct.
  3. computers3
    Dec 8, 2011
    I'm having the same problem.
    When I run "service 3* status" I get the following:
    ● 3cxpbx.service
    Loaded: not-found (Reason: No such file or directory)
    Active: inactive (dead)
  4. computers3
    Dec 8, 2011
    Further to the above, I did change the default ports (via the wizard) to 5011 HTTPS and 5010 HTTP, I have tried both FQDN and IP via HTTP and HTTPS. SIP is working ok, extensions are registered and can receive calls. (I had restored from a backup as part of the installation).
  5. GiannosC_3CX
    GiannosC_3CX Guest
    Hi computers3,
    Please try this command and check if the service is running.
    service 3CXPhoneSystemMC01 status
    #5 GiannosC_3CX, Feb 14, 2017
