Can't connect to SIP trunk
Discussion in '3CX Phone System - General' started by GeorgeW, Feb 9, 2017.
  1. GeorgeW
    Nov 9, 2011
    12
    It's been 4 days and just can't connect to my new VoIP provider (netelip), no matter what change I make on 3cx v15 I always get:
    Registration at Generic VoIP Provider has failed. Destination (sip:##########@sip.netelip.com:5060) is not reachable, DNS error resolving FQDN, or service is not available.
    3cx's firewall tester passes all tests but those on port 9000 since we don't use media tools
    I can ping my provider, firewall port accepts 5060, 5061 and 5090
    Any ideas?
    Thanks in advance.
    10,737
    278
    The error message would seem to indicate that DNS cannot resolve sip.netelip.com.
    You might want to confirm that DNS is functioning correctly (can you ping from PC/Server?), and that information from provider is correct.
    The IP I get for them is 194.140.135.80, you might want to confirm that and use it as a test.
    #2 leejor, Feb 9, 2017
  3. GeorgeW
    Nov 9, 2011
    12
    Like I said, I can ping my provider (sip.netelip.com) and resolves ok to 194.140.135.80, any other ideas?
  4. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Enter that IP in trunk?:confused:
    Something wrong with firmware of (some) routers?
  5. GeorgeW
    Nov 9, 2011
    12
    Same result:
    Registration at Generic VoIP Provider has failed. Destination (sip:##########@194.140.135.80:5060) is not reachable, DNS error resolving FQDN, or service is not available.
  6. leejor
    10,737
    278
    I would contact them and see if they have an explanation. Perhaps they are having issues? If you have one available, perhaps try setting up an ATA to register with them. You could more easlily move that to a different network, to confirm that it isn't something else on your current network ,causing an issue.
  7. GeorgeW
    Nov 9, 2011
    12
    There is no problem with my network, all of 3cx firewall tests are OK. I downloaded StarTrinity SIP tester and registers to the provider with the start up configuration:
    13:07:25.373 [+556.53ms] [RX] OK from 194.140.135.80:5060
    SIP/2.0 200 OK
    Via: SIP/2.0/UDP 192.168.1.202:5070;rport;branch=z9hG4bKPjc3e94d6eaa4448d3b1dfc12be752dc67
    Record-Route: <sip:siproxd@192.168.1.254:5060;lr>
    From: <sip:5940359701@sip.netelip.com>;tag=e63e89c88166409b8f265757a3ef198c
    To: <sip:5940359701@sip.netelip.com>;tag=as5a75e1c1
    Call-ID: 4c63d92aa0ba49bf853a20bf9f30aa4e
    CSeq: 34342 REGISTER
    Contact: <sip:5940359701@201.145.42.45:5060;rinstance=f325328c55d18803>;expires=3600
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
    Server: Netelip
    Supported: replaces
    Supported: timer
    Expires: 3600
    Date: Fri, 17 Feb 2017 19:07:25 GMT
    Content-Length: 0
  8. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,294
    249
    I tried... and getting 401 and 403 errors.
    I do not speak spanish - but from what I can tell I use my webcredentials as the logon for the SIP trunk?
  9. GeorgeW
    Nov 9, 2011
    12
    How did you try?, I am not posting the password for the sip trunk?
  10. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    We can select International on top of page?:confused:
  11. craigreilly
    Feb 1, 2012
    3,294
    249
    I created an account... then suddenly all of my other trunks died. Rebooted server - nothing for 15 minutes. Just magically came back to life. WTF!
  12. GeorgeW
    Nov 9, 2011
    12
    So what do you suggest?, I haven't found another provider that allows to test its service before paying it
  13. nb
    nb Support Team
    Jun 7, 2007
    2,123
    150
    Callcentric for example allows you to test free accounts.
    Ping means nothing. You need to DNS lookup. And you might need to use SRV records.
    USE A SUPPORTED PROVIDER. Which country are you from? I can suggest a couple.
    This message Registration at Generic VoIP Provider has failed. Destination (sip:##########@sip.netelip.com:5060) is not reachable, DNS error resolving FQDN, or service is not available.
    means what is says ASSUMING you are correct that your default route is healthy and goes out properly.
  14. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    It is interesting that manual of this provider mentions port 5481 to access mgmt. consoleo_O
  15. nb
    nb Support Team
    Jun 7, 2007
    2,123
    150
    Oh that means that the manual is still talking about version 10 or 11!!
    God knows what else there is outdated!! Send me the link and provider.. Or send them a message if you have a support contact.
  16. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    netelip_3cx_en.pdf
    ¿Perhaps it is not possible to use trunk until we buy/approve DID?:confused:
    EDIT: Now confirmed that we have to purchase number!
    #16 Sopock, Feb 22, 2017
  17. nb
    nb Support Team
    Jun 7, 2007
    2,123
    150
    Yes I checked. I dont know who said that these are free, but we checked and it allows you only to create a free account on their web site.
    Then when you try to enable SIP trunking or assign the numbers - it asks you for the $.
    Why don't you guys speak to them? This can never be a 3CX problem. Can you contact their support and speak to someone that actually works there?
  18. GeorgeW
    Nov 9, 2011
    12
    They are free for 30 days, I had mine (SIP Trunking and DID), just take a closer look:
    http://www.netelip.com/mx/sip-trunk-enruta-las-llamadas-de-tu-pbx/
