Can't create 2200 extensions?
Discussion in '3CX Phone System - General' started by msnyder, Jul 27, 2017.
  1. msnyder
    Jul 20, 2017
    24
    I'm trying to create and extension for 2201 and I get the error:
    • Given DN number cannot be used
    Doesn't seem to be a system extension... Any ideas?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    561
    Hello @msnyder
    what version PBX are you using? also is your PBX set to 4 digit extensions? can you create the 2202 extension or do you get the same error?
  3. leejor
    11,277
    360
    Is there a SIP ID used somewhere that matches? What happens if you dial that extension number? Check the 3CX Activity log if the call appears to go somewhere.
