can't create or modify profile!
Discussion in 'Android' started by eliwillner, Jun 16, 2010.
  1. eliwillner
    Jun 16, 2010
    Hi, I downloaded and installed on an HTC EVO but entered only cursory information into the profile setup which appeared when I first started the application, since I didn't have all the information with me at the time.
    When I start 3CXPhone now, though, it doesn't register (of course) but it also doesn't give me access to the profiles so I can complete the profile information! When I do "menu", "profiles", it returns with "profiles not available".
    Uninstalling and reinstalling doesn't help.
    Any advice would be appreciated, thanks.
    Eli Willner
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    http://www.3cx.com/forums/3cxphone-for-android-15553.html#p79548
    This link points to the post about HTC EVO
  3. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    Profile management is not possible without a working SDcard
    The message you are getting is when no sdcard is found.
    Do you have an sdcard?
  4. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    try version I sent you in pm
  5. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    We uploaded another version on app store.
    I have feedback that it is visible on x10mini and that it works now.
    Can you try this and let me know? Thanks
