Can't dial PBX Extensions
Discussion in '3CX Phone System - General' started by jimbob, Nov 6, 2009.
  1. jimbob
    Jul 3, 2009
    This is my first attempt at VoIP and I'm sure I've overlooked something.
    I have a 3CX system setup with a few softphones, and also a Patton 4114 Smartnode. I have an extension from our PBX fed into the first FXO port. ( Extension 1000 on our PBX)
    From another PBX extension I can dial 1000 and get the softphone to ring that is setup in the PSTN forwarding rules. I cannot however dial from the softphone to a PBX extension. Nor can I dial 9 to get an outside line on the PBX.
    Any help would be greatly appreciated.
    Thanks much,
    Jim
  2. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    You have to study manual and some VoIP How-to.
    1. PSTN rules not usable when calling from extension to extension
    2. You cannot receive outside line when you dialing 9 (this is not applicable to VoIP PBX)
    3. FXO ports must be connected to Trunks, but not to extensions.
