cant do blind/attended transfert for external call
Discussion in 'Windows' started by Kinder, Sep 9, 2014.
  1. Kinder
    Sep 9, 2014
    We found a problem today with 3CXPhone (last version 12.0.37098.0):
    We can't transfer an external call to an internal extension, either attended or blind transfer : call are ended.
    - blind transfer : target extension doesn't ring (IP phone or 3cxphone) and call is lost.
    - attended : target extension can pick the call, but no transfer option, all greyed out (unlike in the manual http://www.3cx.com/user-manual/transfer/). Only option is "end call", call is lost.
    The phone is in softphone mode, no IP Phone associated with the extension.
    Transfer from other IP phone or presence screen (right clic on call > transfer) is successful.
    Is there anything I missed in the configuration of the 3CXPhone v12? We migrated recently from v11 and 3CXPhone v6.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi there,
    Can you confirm your trunk has following properties in its Advanced tab :
    - Supports Re-invite : not ticked
    - Supports Replace : not ticked
    - PBX Delivers Audio : ticked
    If not please adjust to be so and see if issue persists.
    Furthermore are your 3CXPhone provisioned with welcome email ? in CTI or 3CXPhone mode ?
  3. Kinder
    Sep 9, 2014
    OK, I unchecked the first 2 options, we will try and report back.
    Kinder
  4. Kinder
    Sep 9, 2014
    Ok, it's working again.
    Why was it working in 3CX v11 and not in v12? We migrated from a v11 recently.
  5. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    That I can't say, but those 3 settings I gave you are default for all supported providers...
