Can't do calls. Can't recieve them - Upgrade from v.3 to v.8
Discussion in '3CX Phone System - General' started by juanb, Feb 25, 2010.
  1. juanb
    Feb 24, 2010
    Hi!
    I upgraded to the last version of non commercial 3CX version.
    I have configured my IP soft phones, as also my SPA 941
    I had some VOIP lines from a german provider, and also some lines from one in Argentina
    But the problem comes with the argentinian lines. I think I configured everything like I had, but I always get busy with the arg lines. And I can't do any calls trough them.
    The log I get
    16:06:49.690 [CM503020]: Normal call termination. Reason: Terminated
    16:06:49.690 [CM503016]: Call(6): Attempt to reach <sip:901147803854@192.168.1.6> failed. Reason: Reason Unknown
    16:06:49.690 [CM503003]: Call(6): Call to sip:01147803854@provider.net:5060 has failed; Cause: 405 Method not allowed; warning: Noisy feedback tells: pid=27329 req_src_ip=190.244.116.94 req_src_port=5060 in_uri=sip:01147803854@provider.net:5060 out_uri=sip:01147803854@provider.net:5060 via_cnt==1; from IP:XXX.XXX.XXX.XX:5060
    16:06:49.565 [CM503025]: Call(6): Calling VoIPline:01147803854@(Ln.10004@53529300)@[Dev:sip:1153529300@provider.net:5060]
    16:06:49.268 [CM503003]: Call(6): Call to sip:01147803854@provider.net:5060 has failed; Cause: 405 Method not allowed; warning: Noisy feedback tells: pid=27328 req_src_ip=190.244.116.94 req_src_port=5060 in_uri=sip:01147803854@provider.net:5060 out_uri=sip:01147803854@provider.net:5060 via_cnt==1; from IP:XXX.XXX.XXX.XX:5060
    16:06:49.206 [CM503025]: Call(6): Calling VoIPline:01147803854@(Ln.10003@53529301)@[Dev:sip:1153529301@provider.net:5060]
    16:06:49.159 [CM503004]: Call(6): Route 2: VoIPline:01147803854@(Ln.10004@53529300)@[Dev:sip:1153529300@provider.net:5060]
    16:06:49.159 [CM503004]: Call(6): Route 1: VoIPline:01147803854@(Ln.10003@53529301)@[Dev:sip:1153529301@provider.net:5060]
    16:06:49.159 [CM503010]: Making route(s) to <sip:901147803854@192.168.1.6>
    16:06:49.159 [CM505001]: Ext.109: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Sipura/SPA941-4.1.8] PBX contact: [sip:109@192.168.1.6:5060]
    16:06:49.159 [CM503001]: Call(6): Incoming call from Ext.109 to <sip:901147803854@192.168.1.6>
    I can do calls with the german lines. So I think it is not a router problem
    Any ideas?
  2. juanb
    Feb 24, 2010
    Thanks. The problem is that provider.net doesn't like to give support with people that do not use their Linksys Gateway :x
    The only think they say is that on their side everythink is working fine. And so was it on my side before upgrading!
    Any ideas?
    Thanks!
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    I've deleted my previous post, sorry for the "confuse"
    The straight answer is: We have no any clues to resolve "Cause: 405 Method not allowed" response received from "provider.net".
  4. leejor
    10,869
    304
    I'm wondering if it has something to do with the User Agent info that is being sent to them. You can change that to "fool" them into thinking you are using a Linksys gateway. You may need to know which one they want you to be using.
    Here is a link to a series of posts on how to change that info. It arose when it was discovered that SipPhone had blacklisted 3CX from registering with them.
    http://www.3cx.com/forums/help-with-sipphone-com-not-registering-3254.html
    You could put in something like "SPA3102-5.1.7(GW)" , one of the user agents for a SPA3102 gateway.
    If you do a search for "Sip User Agents" on the net you will come up with a number you can try.
