cant find backup/restore Version 6.1.0
Discussion in '3CX Phone System - General' started by spec, Sep 27, 2008.
  1. spec
    Sep 8, 2006
    51
    Had a big problem with 3cx and it was the older 6.0 or something so I thought uninstall and install Version 6.1.0 and problems could go away.
    Backup the old settings, installed Version 6.1.0, and went to general setting to restore the config. But it was not there
    So my question where has the backup/restore been moved to??? cant find it
  2. spec
    Sep 8, 2006
    51
    got it maybe my old one was older thyan the Version 6.0.
    its been taken out of general setttings and its now in the start button/all programs/3cx phone/Backup and Restore Tool
