Solved Can't find Outlook integration
Discussion in 'CRM / Helpdesk / App Integration' started by Shawn, Oct 31, 2017.
  1. Shawn
    Shawn New Member
    Feb 2, 2017
    114
    I'm following https://www.3cx.com/docs/microsoft-outlook/
    but can find the Dashboard > Updates > Integration category
    we have pro 15.5.3849.1
    I'm looking to be able to dial contacts using 3cx directly from outlook (2010 and above)
    Shawn
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,473
    94
    Go to Settings > CRM's > Client Side CRM's, give it a look there.
  3. Shawn
    Shawn New Member
    Feb 2, 2017
    114
    thank you for pointing me in the right direction. that did it.
    shawn
